Weight watchers project
chris white
Been thanked: 175 times
The track car is heading out for cage work so I thought I would weight it just for fun.
Need to add cage, transmission, front clip (fiberglass), windshield and Kenan hatch and wing. Also exhaust system(cat back).
I’m liking the result of stripping weight!!!
Has thanked: 4604 times
Been thanked: 2498 times
chris white wrote: Fri May 12, 2023 11:56 am The track car is heading out for cage work so I thought I would weight it just for fun.
So, I like going out on limbs - another (edit) 450 to 500 lbs without fuel? (Probably way off but I tried!)
Will you have to add weight to corner balance once it's complete?
chris white
blueline wrote: Fri May 12, 2023 12:28 pm
I was thinking 400-450 more weight, biased toward the rear (transmission).
corner balancing doesn't mean the same front/rear - just the same side to side with the driver on board. changing the spring seat height will get that done.
2200 lbs with 500rwhp will do just fine!
Thom
The First Carpoke!
Has thanked: 140 times
Been thanked: 159 times
How old are those S-02s?
'90 944 turbo
chris white wrote: Fri May 12, 2023 12:58 pm
Indeed it will. Nice!
chris white
Thom wrote: Fri May 12, 2023 1:14 pm How old are those S-02s?
at least 20 years - those are the 'roll around & trailering' wheels/tires!
chris white
blueline wrote: Fri May 12, 2023 1:48 pm
I want to taunt the 911 cup cars!!! :)
chris white wrote: Fri May 12, 2023 1:50 pm
I have no doubt that you will accomplish that goal. :thumbup:
I'll be eagerly awaiting the updates!
SirLapsalot
Been thanked: 19 times
Who’s doing the cage? What are you doing for design?
I just dropped my car off to be caged and always curious to see others designs.
Has thanked: 538 times
Been thanked: 279 times
I assume that tank in the right front is for dry sump? What size is that?
