The track car is heading out for cage work so I thought I would weight it just for fun.
Need to add cage, transmission, front clip (fiberglass), windshield and Kenan hatch and wing. Also exhaust system(cat back).
I’m liking the result of stripping weight!!!
Weight watchers project
- chris white
- Been thanked: 175 times
- D63172FA-B3A9-406F-8F7F-057ED98AA731.jpeg (2.31 MiB) Viewed 1756 times
- 6293F9F8-7CFC-4FFA-B964-193678A45962.jpeg (3.55 MiB) Viewed 1756 times
- Has thanked: 4521 times
- Been thanked: 2452 times
So, I like going out on limbs - another (edit) 450 to 500 lbs without fuel? (Probably way off but I tried!)chris white wrote: Fri May 12, 2023 11:56 am The track car is heading out for cage work so I thought I would weight it just for fun.
Will you have to add weight to corner balance once it's complete?
- chris white
I was thinking 400-450 more weight, biased toward the rear (transmission).blueline wrote: Fri May 12, 2023 12:28 pmSo, I like going out on limbs - another (edit) 450 to 500 lbs without fuel? (Probably way off but I tried!)chris white wrote: Fri May 12, 2023 11:56 am The track car is heading out for cage work so I thought I would weight it just for fun.
corner balancing doesn't mean the same front/rear - just the same side to side with the driver on board. changing the spring seat height will get that done.
2200 lbs with 500rwhp will do just fine!
Indeed it will. Nice!chris white wrote: Fri May 12, 2023 12:58 pmI was thinking 400-450 more weight, biased toward the rear (transmission).blueline wrote: Fri May 12, 2023 12:28 pmSo, I like going out on limbs - another (edit) 450 to 500 lbs without fuel? (Probably way off but I tried!)chris white wrote: Fri May 12, 2023 11:56 am The track car is heading out for cage work so I thought I would weight it just for fun.
- chris white
at least 20 years - those are the 'roll around & trailering' wheels/tires!
- chris white
I want to taunt the 911 cup cars!!!blueline wrote: Fri May 12, 2023 1:48 pmIndeed it will. Nice!chris white wrote: Fri May 12, 2023 12:58 pmI was thinking 400-450 more weight, biased toward the rear (transmission).blueline wrote: Fri May 12, 2023 12:28 pm
I have no doubt that you will accomplish that goal.chris white wrote: Fri May 12, 2023 1:50 pmI want to taunt the 911 cup cars!!!blueline wrote: Fri May 12, 2023 1:48 pmIndeed it will. Nice!chris white wrote: Fri May 12, 2023 12:58 pm
2200 lbs with 500rwhp will do just fine!![]()
I'll be eagerly awaiting the updates!
SirLapsalot
- Has thanked: 1 time
- Been thanked: 19 times
Who’s doing the cage? What are you doing for design?
I just dropped my car off to be caged and always curious to see others designs.
