Max 5psi boost after turbo install
I’ve suggested this video on several other threads. So you might have seen it. But I highly suggest to watch, it will really help you understand everything around wg and boost controllers. I watched it maybe 3-4 times before it all sunk in and made sense. The bulb will go on and you might be able to answer the questions you have.
Shameless plug, I have the A-Tune chip along with MAP sensor and Bosch 3 bar fpr. This will also help with down low performance. PM if you’re interested.
Last suggestion speaking from experience
just do the upgrades to a dual port and mbr, sport cat, and chip if you can (but you don’t need a chip with a Tial or any wg). Bite the bullet cause nothing is easy but this is as easy as it gets. you will like the early spool up.
chrischrischris
- Has thanked: 4 times
- Been thanked: 33 times
How do you upgrade to a sport cat? Do you mean cut out the stock and weld in something else?
Yes. Or buy a complete setup from Fabspeed or Lindsey among others.chrischrischris wrote: Fri Jun 05, 2026 1:04 pm How do you upgrade to a sport cat? Do you mean cut out the stock and weld in something else?
- danmartinic
- Has thanked: 23 times
- Been thanked: 41 times
The MAP sensor that came with my A-Tune was terrible: when it began to fail, all the drivability symptoms pointed to a million other things.. then I had a unusual idea to test the MAP and sure enough, it was very erratic. I bought a Delphi replacement --it's for specific GM cars such as Fiero or Firebird-- and problems solved944m3 wrote: Fri Jun 05, 2026 12:11 pm
You can buy Chinese knockoffs for peanuts and I suspect that's what came with the chip
Note that the official tech paper for it instructs mounting high & nearly horizontal to avoid moisture contamination.. hard to accomplish for us.. so regularly checking the voltages almost routine now
Point of the story is unfortunately, many upgrades add more things that can fail and make diagnosing issues harder
chrischrischris
I was reading about the A-tune. It's pretty cool that you get 3d mapping with their chip, providing your MAP sensor is working. Did any other vendor produce anything comparable?
My car is 1987 with the 24 pin chip socket, so I would need to change or modify my DME to use this option. Currently using the 24 pin Lindsey Maxx chip, which is pretty good.
I don’t believe there was anything similar. Considering piggybacks or full standalone complexity the A-Tune was very simple to install by comparison. Not sure why it wasn’t further developed. Perhaps because it didn’t really add power it just smoothed out power delivery. You really feel it in first and second gear. Much more responsive.
Glassmuseum
- Has thanked: 10 times
- Been thanked: 3 times
Yep thank you. I have seen it but I am going to watch it again. And prob again..944m3 wrote: Fri Jun 05, 2026 12:11 pm I’ve suggested this video on several other threads. So you might have seen it. But I highly suggest to watch, it will really help you understand everything around wg and boost controllers. I watched it maybe 3-4 times before it all sunk in and made sense. The bulb will go on and you might be able to answer the questions you
Interested. Will pm.944m3 wrote: Fri Jun 05, 2026 12:11 pm Shameless plug, I have the A-Tune chip along with MAP sensor and Bosch 3 bar fpr. This will also help with down low performance. PM if you’re interested.
I am headed exactly in this direction. Incrementally though.. The problem I have now is in what order and how I should run it (dual vs single). I am leaning towards replacing the wastegate first with Tial and either a MBC or EBC. Then complete exhaust. And then chip upgrade. Looking at this exhaust from Lindsey with cat944m3 wrote: Fri Jun 05, 2026 12:11 pm Last suggestion speaking from experiencejust do the upgrades to a dual port and mbr, sport cat, and chip if you can (but you don’t need a chip with a Tial or any wg). Bite the bullet cause nothing is easy but this is as easy as it gets. you will like the early spool up.
https://www.lindseyracing.com/LR/Porsch ... XH-32.html
I may try to replace the stock wastegate stud and see if it helps. But I feel like that’s going to be close to as much work as it would for replace it. So I’ll have to see.. Assuming when you mentioned “mbr” you are referring to manual boost controller? Thanks again.
chrischrischris
When I removed my stock wastegate I broke every stud. Glad I had no intention of reinstalling. I think some decent machine shop tools and/or experience is needed to tackle these studs, so make sure you are careful picking your battles.
Also, sounds like the a-tune would be a nice upgrade for anyone but that particular setup may not be plug and play with your particular ECU since you may have the 24 pin DME. If so, there are a few ways to upgrade your DME to accept a 28 pin, but you should know if you need to plan for that.
