Cylinder Head rebuilt recommendations
Has thanked: 941 times
Been thanked: 4027 times
libarra82 wrote: Wed Jan 21, 2026 6:48 pm Received the air compressor today. Shot air into the spark plug port and it all went out of the jboot, dang.
Odd that it was just that one valve, I would think cylinder one would be bent also, but that was good. Lifter on that valve is very chatty, maybe it too stiff and didn’t let the valve close all the way and hit the piston?
I’ll tear it all down this weekend to assess the damage.
Was the motor still at TDC with the marks lined up when you tried the compressed air? If so, #4 would be on the intake stroke with the intake valve already open (partially), allowing all the air to come out the intake/jboot (and possibly still some out the exhaust -- I'd need to look up the cam specs). If that's what you did, rotate the motor exactly one revolution so that #4 is at TDC compression, and try again...
libarra82
Been thanked: 10 times
Will try. It is currently at TDC.
libarra82
Air escapes through the jboot no matter where I am in the rotation. Exhaust valve does close.
libarra82 wrote: Wed Jan 21, 2026 7:31 pm Air escapes through the jboot no matter where I am in the rotation. Exhaust valve does close.
Well that would indeed suggest a bad intake valve... Definitely let us know what you find!
libarra82
Found something interesting today. I injected air into each cylinder with all the spark plugs out. Found that air from cylinder 4 is leaking into cylinder 3.
I think when inserting air into cylinder 4, it’s leaking into cylinder 3 then up the intake. I may not have a bent valve after all. Head gasket hopefully, fingers crossed.
PSU_Crash
Has thanked: 191 times
Been thanked: 111 times
libarra82 wrote: Fri Jan 23, 2026 11:27 pm Found something interesting today. I injected air into each cylinder with all the spark plugs out. Found that air from cylinder 4 is leaking into cylinder 3.
If that's the case then you should have measured bad compression on both 3 and 4. Waiting for pictures with the head off :P
libarra82
Yeah it was late last night and didn't think it through. Air just going up the intake, though the manifold and into cylinder 3 lol. Will see what happens later today.
libarra82
Here is the valve, not closing completely. There’s a small sliver of something on the lower right.
libarra82
Stopping here for the night. Head ready to come out first thing in the morning.
Good work for one day! Now that the cam tower is off, did you inspect that valve spring/stem from above for anything obvious?
Looks like a very tidy, original engine bay. I worry about any car with original fuel lines, however, as those appear to be. Consider installing the Rennbay fuel line kit while you're at it....
#20
