Gas gauge only goes to 1/4
I had pulled the cluster out to fix the odometer and replace the bilbs with LEDs. Now my gas gauge was at 0 put gas in it and it only went to 1/4 tank ish? Any ideas before i pull the dash out again? The likely culrit maybe being one of the plugs not seated?
- Has thanked: 934 times
- Been thanked: 4005 times
Did it work right before you pulled the cluster? That's normally a sticky sender in the tank.
Given it is much easier to get to the tank connections, I would disconnect, then short the gage wire (blue/black early, looks like green on late cars.) Gage should read one way when shorted, the other when open.
