Gas gauge only goes to 1/4
seiplej
Has thanked: 5 times
Been thanked: 4 times
I had pulled the cluster out to fix the odometer and replace the bilbs with LEDs. Now my gas gauge was at 0 put gas in it and it only went to 1/4 tank ish? Any ideas before i pull the dash out again? The likely culrit maybe being one of the plugs not seated?
Been thanked: 4025 times
Did it work right before you pulled the cluster? That's normally a sticky sender in the tank.
seiplej
As far as I know yes it was working correctly. I just bought this car late Nov and tackling all the small issues and maintenance to get it ready for spring.
944er
Has thanked: 14 times
Been thanked: 54 times
seiplej wrote: Sat Feb 01, 2025 7:26 pm Any ideas before i pull the dash out again?
Given it is much easier to get to the tank connections, I would disconnect, then short the gage wire (blue/black early, looks like green on late cars.) Gage should read one way when shorted, the other when open.
