Rod Bearing clearance with Carrillo Rods?
Cruise98
Has thanked: 16 times
Been thanked: 23 times
I talked with a friend at a local shop today who mentioned they have had problems with Carrillo rods in 911 engines when running factory clearances. Is this an issue for the 944 engines as well?
I am about to install a fresh engine and am using the Carrillo rods and the ACL bearings with the factory clearances.
Does anyone have experience with this? Thanks.
Has thanked: 936 times
Been thanked: 4025 times
My 3L motor has Carrillo rods and factory clearances. No known issue here after 35k miles or so. I'm thinking the Internet would be full of stories if there was an issue, since lots of Carrillo rods are out there...
Cruise98
This is good news. I have not run across any comments on it for 944's either. Thanks
gruhsy
Has thanked: 48 times
Been thanked: 81 times
What weight oil are you going to use?
https://www.enginelabs.com/engine-tech/ ... confusion/
Interesting read…..article is mainly about side clearance but talk’s about bearing clearance also.
https://www.enginelabs.com/engine-tech/ ... materials/
Cruise98
After break-in I will run VR-1 20w-50 most likely. May run 5w-40 Motul as I have a couple of boxes of that from a long gone BMW.
Interesting articles. It seems that more clearance is better up to a point. Kind of like ring end gaps.
Thanks.
blade7
Has thanked: 26 times
Been thanked: 22 times
When I bought my turbo 15 years ago, I used 5w-40, and had one or two oil drips on my drive. Switched to 15w-50 and the oil drips dried up.
cda951
Has thanked: 136 times
Cruise98 wrote: Tue Nov 28, 2023 3:50 pm I talked with a friend at a local shop today who mentioned they have had problems with Carrillo rods in 911 engines when running factory clearances. Is this an issue for the 944 engines as well?
I am curious about the specific issue your friend's shop has seen with this rod/bearing combo. Too little clearance and wear/spun rod bearings? Too much clearance?
More information would be helpful.
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
cda951 wrote: Fri Dec 01, 2023 11:11 pm
I'm a cynic, so would also be curious if they have a different brand they prefer to promote.
Cruise98
He said that the factory clearances were not enough. The Carrillo rods are very stable and do not grow like the factory rods. They are fans of Carrillo's and use them frequently. No agenda there.
I do not want to start any rumors about air cooled 911 engines, but they claim do have discussed it with Ollie's in CA.
Cruise98 wrote: Sat Dec 02, 2023 5:32 pm He said that the factory clearances were not enough. The Carrillo rods are very stable and do not grow like the factory rods. They are fans of Carrillo's and use them frequently. No agenda there.
Just with those bearings or even with the stock bearings? I have no first-hand experience with them on a 911, so take my comments/cynicism with a grain of salt. Just curious and wondering out loud really. 8-)
