944 Late Offset Speed Force Racing (SFR) Control Arms
Post things for sale here!
usury
Has thanked: 100 times
Been thanked: 93 times
For Sale: $600 (USD, obo)
Make me an offer if you think I'm way off on valuation.
Speed Force Racing Control Arms for Late Offset Porsche 944. These are the mild steel version from 2017, prior to when they began using the full plate. One side has left-hand threads for the heim. Included is a spare brand new heim-to-spindle pin.
  • Late Offset
  • Mild Steel
  • From 2017
  • One new heim
  • Other heim has about 1k miles
  • New Red Urethane AutoFab B125 Bushings* (see below photos)
  • New Spare heim-to-spindle pin
  • Excess 12mm ID thick-wall aluminum spacer sleeve material
  • NOT used on a race car - street car only
Overview 1
Overview 1
Overview 2
Overview 2
Description
Description
Pins and Heims
Pins and Heims
Spare Pin
Spare Pin
New Bushings
New Bushings
Extra AL Spacer Material
Last fall I stripped them to bare metal and painted them blue, because I like blue.
Painting Collage
Painting Collage
These are the OLD rubber bushings and steel spacer sleeves.
Old Rubber Bushings and Sleeves
Important Things
  • *The red urethane bushings are brand new (AutoFab B125)
  • Neither the original black rubber bushing nor the new red urethane bushings were an easy press-in fit
  • I never uunderstood how to fit them properly
  • you'll probably want to source new bushings and spacer sleeves
  • The bushings seemed quite oversized for the hole they go into
The original steel bushing sleeves that came with the control arms had become pitted with corrosion. The replacements sleeves that I ordered from AutoFab for their B125 bushings were the wrong size to fit over the bolt that goes through them. So I found some 12mm ID thick walled aluminium that fits.
That's when I decided I'd rather rebuild my stock control arms and sell these to someone who knows how to use them.
In Another Thread About Returning to Stock Control Arms, I replied to someone who asked what I didn't like about these control arms. This is what I said...
The tubular steel arms are probably great. The welds are beautiful and the construction is solid.
However, I've never really known how to set them up so I've never been confident in them.
The bushings were difficult to fit properly, and the adjustable heim provides way more camber adjustability than I'll ever need. I was never really sure if I had the heim joints in the factory location since fully bottomed out would be way positive camber.
Plus, I've never understood why one has left-handed threads, nor on which side that one belongs.
Since the control arms didn't come with an instruction sheet, and I could never locate one, I figured they are really intended for people who already know those kinds of things. I didn't want to reveal my ignorance previously, so I never asked.
So, PM me. I'm happy to sell them to you. I'm in located in the greater Seattle area for an in-person sale. Or I'm happy to ship (US, definitely. Canada, maybe. Overseas, probably not unless you can really convince me. :) )
and Wrench Warrior
Seattle, Washington, USA
Jay Wellwood
Has thanked: 113 times
Been thanked: 43 times
So…did you sell them?
Jay
...looking for a Meatball
usury
Jay Wellwood wrote: Mon Jun 12, 2023 4:55 pm So…did you sell them?
Not yet... Are you interested?
and Wrench Warrior
stitch2k1
Been thanked: 30 times
What do they use for caster blocks? I was going to rebuild the arms on my S2 but I would not be opposed to these instead. Going to updated 968 casters anyway, figuring that's what these need.
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
usury
stitch2k1 wrote: Thu Jun 15, 2023 4:35 pm What do they use for caster blocks?
They do use the stock Porsche caster blocks, not necessarily the 968 ones. (Mine is an '87na.)
I don't have a picture that specifically shows the caster block end of these mounted to the car, but this pic should give some idea...
Edit: I do have a better pic...
and Wrench Warrior
stitch2k1
Yeah those are the '968 casters'
IG: @stitch2k1
usury
Sure enough they are. The caster blocks in those pics are these, pn 951-341-023-01-HBT
https://www.pelicanparts.com/More_Info/ ... DID=208833
Fitment from '85na to '95 968 according to Pelican.
I installed these new caster blocks last summer/fall. Prior to that the car had its original 35-yr-old caster blocks. New suspension stuff is nice.
and Wrench Warrior
stitch2k1
Really want these, but I went ahead and rebuild my original arms with Travis' (Rennbay) help this morning. At 150k miles both ball joints were only starting to fail, and one arm bushing was perfect and the other was just starting to fail thanks to fluid leaks.
IG: @stitch2k1
usury
The Rennbay kit is great. I used it to rebuild my factory control arms, too. I think I made a post about it even.
Congrats on the rebuild! If you haven't already, replacing the rubber sway bar bushings also makes a noticable difference.
and Wrench Warrior
stitch2k1
I have poly bushings on my F/sway bar (26.8) and my R/sway is on original bushings (fine cond.) but the links are adjustable helm joints from BDR.
Trying to find a 30mm hollow and 19mm 3 way (or 5 way) adjustable, second hand.
Porsche only sells the 30mm solid one now.
IG: @stitch2k1
