Boxster/Cayman spare tire FS
- Bill in Bama
- Has thanked: 16 times
- Been thanked: 155 times
I have a new spacesaver spare that fits 986/987 Boxsters, 987 Caymans, and some 981's. It also fits some 911's but I'm not sure which. Suncoast sells this with jack and foam insert for $1000. I don't have the jack but do include the insert and cover for $250, shipping extra, or local pickup. I'll post up some pics when I get a chance. This is the one inflated to 60 psi, not the collapsible one you have to inflate.
'84 944, my first Porsche DBM
- Bill in Bama
Finally got around to taking pics, here they are.
- Posrche spare 2.jpg (167.33 KiB) Viewed 600 times
- Bill in Bama
I didn't check the code to see how old this tire is, but it is 14-15 years old at least as I've had it since 2009. While out of date, it still has 60 psi and has been holding for a couple of years at that pressure. Prudence would dictate replacing the tire, YMMV, but for what it is designed for and the speed limit placed on it (50 mph), it probably is still OK. Anyway, the wheel is fine, as is the foam insert (which I've seen go for over $100), and the cover has some spider webs on it from sitting in a corner of my garage but is otherwise in fine shape. I'll entertain reasonable offers, shipping is the big expense anyway. It WON'T fit a 718, I've confirmed this, which is my reason for selling, but I know it fits the 986/987 models and some 981's as well, depending on the size of the brakes. It is a 17" diameter wheel so keep that in mind.
