New DIY subforum for Macan
This forum is for detailed DIY guides relating to the Macan
At @Teddis's suggestion, I broke out a separate sub-forum for detailed DIY guides, and moved @santirx's video guides here. The idea would be every new topic/thread in this subforum should be a detailed DIY guide relating to the Macan. General questions and discussion would still go in the main Macan forum, but questions or comments about an particular DIY are ok to post in that DIY's thread, if that makes sens.
@kapetajr, @johnb, @rasetsu, @VA_CT
Open to suggestions on further organization.... but in the meantime, keep up the great work! Would love to see Carpokes become a go-to source for Macan tech!
Teddis
Has thanked: 22 times
Been thanked: 39 times
Excellent , This removes “clutter” from the main and makes searching easier.
Onwards Tom !
santirx
Been thanked: 25 times
Thanks Tom. This makes sense.
Thanks guys. This is your board to run with, so if this (or whatever else) helps, I'll do whatever I can to help make this the place where you want most to talk Macans... I'm not plugged into the Macan world all that well, so the more you spread the word yourselves, the quicker it will grow I'm sure. In the meantime, santrix's DIYs are an awesome head start!
VA_CT
Has thanked: 23 times
Been thanked: 10 times
Thanks Tom! for this sub forum. Its a great start.
kapetajr
Has thanked: 203 times
Been thanked: 32 times
Thank you very much Tom. We appreciate you being open to feedback and suggestions. 👊🏿
