931 Timing belt tensioning
- painenneck
- Has thanked: 2 times
- Been thanked: 4 times
I just replaced mine, though not a turbo but same engine, and I used the twist method to measure tightness. It is not as critical as on the 2.5 as the 2.0 is a non-interference engine...but a failed belt will leave you stranded either way, just not as costly.
- Been thanked: 4016 times
I'm not a 924/931 expert by a long shot, but I thought the turbo version of that motor was an interference motor, unlike the n/a version....painenneck wrote: Fri Jul 08, 2022 6:59 am I just replaced mine, though not a turbo but same engine, and I used the twist method to measure tightness. It is not as critical as on the 2.5 as the 2.0 is a non-interference engine...but a failed belt will leave you stranded either way, just not as costly.
- painenneck
You're right; I stand corrected.
- painenneck
I have a 944 also that I use the twist method for the belts...but I also run with scissors so...
Zirconocene
- Has thanked: 78 times
- Been thanked: 48 times
@Tom : I only just saw the part you designed, via the newsletter, but any chance that your tension tester will work for the 924? I know just about zero with those cars, but your tool is really slick and might be something useful here.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Well, I'm sure the concept could be adapted for the original 924 motors, and the 928 for that matter (and whatever else), but the current 944 tool is heavily dependent on the physical layout of the 8v 944 motor (pivot point boss, water pump rail, location of belt, etc.). I think it's safe to say this tool would not work on that motor. No reason we couldn't work on a tool for other motors if there is demand for one, however... I'm hoping to do a 944 balance shaft tension tool next.Zirconocene wrote: Fri Jul 08, 2022 8:33 am @Tom : I only just saw the part you designed, via the newsletter, but any chance that your tension tester will work for the 924? I know just about zero with those cars, but your tool is really slick and might be something useful here.
Zirconocene
Gotcha. I've never seen a 924 motor in person, much less taken note of bolt placement, etc., so I guess I was hoping that maybe there was a lucky shortcut.
In any case, I am totally on board with the balance belt tensioner being next up, as well as anything you have in mind that's 928 related.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Post some pictures of those 928s, including in the Excellence picture thread if you are so inclined.Zirconocene wrote: Fri Jul 08, 2022 10:06 am Gotcha. I've never seen a 924 motor in person, much less taken note of bolt placement, etc., so I guess I was hoping that maybe there was a lucky shortcut.
Zirconocene
I'm totally inclined, but my cars are a mess right now. I'm doing a motor mount, oil pan gasket, and steering rack rebuild on the S4, and the GT is sort of in pieces, as it was bought as a project after some body damage. Depending on the timing, the S4 might be off the lift in time to submit something and I would *love* to see my car in print (excited fanboy noises follow).
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
