Porsche released a new recall for the Taycan this past week. The PCM can blank out and not fully boot. We've had it happen several times, and seems to be more frequent in the last couple of weeks.
Software update is still not available, it's expected dealers will have the update sometime in August. I'm hoping it's sooner. You can login to your Porsche account and it will tell you if your car is covered by the recall or not.
https://static.nhtsa.gov/odi/rcl/2022/R ... 4-5800.PDF
Programme main computer (PCM)
Campaign number ANA6
Date of recall report: 6/22/22
Summary
Recall cause is a software error in the central computer (PCM).
Effects
The affected vehicles potentially show two error symptoms: 1. The center and passenger displays and the touch control panel directly do not start when the ignition is on. 2.The Real-Top-View (RTV) is displayed with a flickering image.
Corrective measures
THE REMEDY FOR THIS RECALL IS NOT YET AVAILABLE. The PCM must be re-programmed with corrected software. Due to the related functional enhancement of the central computer, the driver's manual must also be replaced with an updated version.
New Recall: Re-programme main computer (PCM) Campaign number ANA6
- Been thanked: 4025 times
Hmmm.... the PCM on my 992 had to be replaced. The screen would go monochromatic in a random color. Probably unrelated, but still curious.
