718 and 991 Drive Mode Dial Cover
Has thanked: 943 times
Been thanked: 4032 times
Attached is the .STL file for the 718 and 991 Drive Mode Dial Cover. Best if printed at 50 micron layer height (or lower) in a resin printer.
718 and 991 Drive Mode Cover by Carpokes V14.stl
Works just like the 992/Taycan version...
maglianera
Most odd. I can post a reply, but it still says I need to be registered and logged in to download files....
You need at least one post to download. I'll update that message to say that with the next set of updates. You should be good to go now....
maglianera
Ah - so the moaning worked xD
Got it now - thanks!
