https://www.calicocoatings.com/index.php
Anyone Calico coat the Gylco main bearings?
Main bearings
michaelmount123
- Has thanked: 26 times
- Been thanked: 179 times
Main bearings on the 944 are nearly indestructible unless there are other factors. There's no need for any coating. Different story on the rod bearings, as you know. Use the ACL Race rod bearings which are now generally available and cheap. Stay away from the Glyco rod bearings.
MM
MM
