Shift Rod Removal
eccs19
Has thanked: 56 times
Been thanked: 6 times
Long story short. My shift linkage at the transaxle was ceased up. I took it out and rebuild it. But my mistake was installing it wrong. (shaft from the shifter rod should have been down, but I installed it with it on the top) Needless to say, everything was binding on the frame and I wasn't able to get the linkage assembly back out easily. Lower the transaxle an inch or so, just to I'd have a bit of working room. I got it removed from where it goes into the transaxle, but in trying to get everything apart, it seems I damaged the shaft and or end of the shift rod, as it's just stuck in there and I'm unable to get it out. I think I'm going to have to take the shift rod out to repair it, but not sure what all is involved. I suspect at minimum the transaxle needs to come out. Any insight from the experts?
NC944er
Has thanked: 8 times
Been thanked: 36 times
I'm trying to follow what happened here...
Which piece of the shifter linkage was installed upside down? And what part is now damaged/stuck as a result?
Posting some pictures of your setup may help or you can reference the below diagram.
eccs19
NC944er wrote: Wed Jul 15, 2026 8:09 am I'm trying to follow what happened here...
Assembly 18 was installed wrong. I did end up getting everything removed with a lot of effort and maybe a bit of swearing, but all good now. Basically when I reinstalled the 2 way nylon bushing, I has it backwards. The shaft that goes into the shifter rod was in the upper position instead of being down. I should have realized something was wrong when it was difficult to reinstall, but I mess up and just did it. (unfortunately)
NC944er
Ahhh, I got you now! Yeah, that would definitely throw off the geometry a bit. Glad you got it sorted out.
And we all make mistakes, it's part of the process. On to the next project with new experience! :thumbup:
