Tips for clutch master/slave cylinders?
spacecad3t
Has thanked: 92 times
Been thanked: 75 times
Got a leaky clutch master. Everything I read says just replace the rubber-hard line and slave. I don't see any leaks from the line or slave cylinder. I picked up all 3 and a power bleeder.
Any experience/tips for this one?
O875
Has thanked: 47 times
Been thanked: 11 times
Often if one (master or slave) is leaking or on its way out then the other isn't far behind, so often both will be done at once to save doing the other soon after.
Perhaps the same idea is behind the rubber-hard line replacement.
Wespa
Been thanked: 26 times
If you have no idea whether all the components were already replaced at some point then it's about time to do so. Trust me, you'll only want to bleed the clutch once, it's a pain even with a Power Bleeder. :mrgreen:
944 NA ROW -86
whalenlg
Has thanked: 8 times
Been thanked: 119 times
Make sure to keep the fluid reservoir topped up - there is a divider in the middle between the brake and clutch ports and bleeding the clutch will drain the front half faster - it may look like there’s enough fluid, but air gets sucked into the clutch side.
Also - my master failed right after a clutch replacement, so that’s also a good time to replace master and slave.
1986 951 - Silicon Valley
cda951
Has thanked: 148 times
Been thanked: 83 times
I was going to ask which year/type of 944 you have, but because you posted in the NA section I will assume you have one of these. The clutch hydraulic circuit can be a pain to bleed because the hard line from the master cylinder is routed above and along the top of the firewall and behind the oil filler/AOS before the bend that takes the fluid down the clutch slave cylinder. This results in air trapped at the high point of the circuit. There are many, many threads on 944 forums over the past couple of decades advocating methods of all sorts for bleeding this circuit. What I describe below is the best method, as long as one keeps the fluid level in the forward portion of the reservoir above the clutch intake hose!
After the initial bleed---can be pressure or vacuum bleed, reverse bleed, manual, etc---there will likely still be air trapped at the high point of the circuit. The solution is to grab a pair of 11mm wrenches, one being a quality flare-nut wrench (this is one instance where paying the big bucks for Snap-On is key, see first pic), stuff the area with rags, and use a helper or a pedal prop (the latter is my go-to, see second pic, I'm usually working by myself at the shop on an evening or weekend) to hold the clutch pedal down, then crack open the union shown at the top of the firewall. You will likely see and hear air bubbles escaping. Tighten the union, lift the clutch pedal by hand, hold it down again, rinse and repeat.
After 4-6x of this process, all the air should be gone. This works EVERY time.
IMG_0432 2.jpeg (2.57 MiB) Viewed 257 times
IMG_0434 2.jpeg (2.52 MiB) Viewed 257 times
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
spacecad3t
cda951 wrote: Wed Jun 03, 2026 10:11 pm I was going to ask which year/type of 944 you have, but because you posted in the NA section I will assume you have one of these. The clutch hydraulic circuit can be a pain to bleed because the hard line from the master cylinder is routed above and along the top of the firewall and behind the oil filler/AOS before the bend that takes the fluid down the clutch slave cylinder. This results in air trapped at the high point of the circuit. There are many, many threads on 944 forums over the past couple of decades advocating methods of all sorts for bleeding this circuit. What I describe below is the best method, as long as one keeps the fluid level in the forward portion of the reservoir above the clutch intake hose!
Appreciate the guidance! I do happen to have a set of snap on flares :) but no pedal prop, thats neat. I'll likely bug a friend to help me bleed it. My plan is to use a power bleeder, which I have already. But will keep this advice in mind.
jeyjey
Has thanked: 36 times
Been thanked: 36 times
spacecad3t wrote: Fri Jun 05, 2026 3:35 pm.... I'll likely bug a friend....
Good idea. I've had mixed results (at best) bugging the wife....
'87 944 NA
spacecad3t
I got it done this afternoon. Aside from the master cylinder flare nut taking many many tiny turns to disconnect it, the rest went relatively smoothly. A couple of observations...
My master cylinder was toast! When I disconnected the rod from the pedal, the rod and boot just fell out. Im surprised it had not failed on me sooner. My slave cylinder looked pristine, but I replaced it anyways, and when I disconnected the metal-rubber line, sure enough that rubber section was gonzo... several worn sections exposing the inner lining.
The motive power bleeder is "clutch" :D
But, let me ask the experienced pros here, how does this sound?
- I filled the reservoir and the attached the power bleeder empty.
- I primed the system to 12-13psi using the power bleeder and checked for leaks.
- I then bled the slave a tiny bit. Checking for leaks.
- I filled the power bleeder with brake fluid and then primed it again.
- I then bled the slave while also pumping the pedal until only fluid was coming out.
With the car off it shifts through all the gears smoothly. Then I started the car and did a reverse and forward test. Unfortunately it then started to rain, so I didn't fully drive it through all 5 gears, I'll do that tomorrow... but in general, would I notice air in the system even just simply moving the car around in reverse and first?
jeyjey
spacecad3t wrote: Sat Jun 06, 2026 5:24 pm... but in general, would I notice air in the system even just simply moving the car around in reverse and first?
Yes, you would. I think you're good to go....
'87 944 NA
