1987 Porsche 944 Automatic Transmission
Trouble
Been thanked: 5 times
Guys, Does anyone know the correct amount of gear oil type and amount to service on the Automatic Transmission??? This is NOT to be confused with the transmission pan and filter service, I’m specifically referring to the gear fluid service, I DONT think this transmission HAS a fill AND a drain plug, All I can see is the 17mm filler plug at the top, Does the gear oil have to be sucked out from the fill plug and pumped back in through the same plug??? I’m getting multiple answers from people who are getting it confused with the Manual Gear box…
spacecad3t
Has thanked: 92 times
Been thanked: 75 times
I could be wrong with the 944, but I had several VW's that had the same automatic. The process was to suck it out, I had a hand pump, and then refill enough to where the oil is level with the hole. Or if you put your pinky in there, you can touch the oil with your finger tip. I remember using 80w90 gear oil.
Trouble
I think you’re RIGHT SpaceCad, I’ve looked ALL over the gearbox even with the 5sp manual side by side and the automatic has only 1 plug…. I never gave it a second thought, But you are ABSOLUTELY correct about this being a Vanagon Automatic…. Do you happen to remember ABOUT how much fluid goes in??? I can understand the fill till it spills…
O875
Has thanked: 47 times
Been thanked: 11 times
Looking at the FSM dated 1986, the Type 087 auto trans uses about a litre (1.06 US qt) in the final drive section of SAE90 (fill to the edge of the filler plug).
Plug tightened to 20Nm (14 ft lb).
The manual neglects to mention how to fill the final drive section...
Trouble
Thank you 0875, It MUST be the suck and fill method because I don’t think the automatic’s have the 2 plug 17mm’s I appreciate ALL the help from you guys!!!👏👏👏
spacecad3t
@Trouble I dont remember, but 0875 beat me to it anyways... Yeah, I had a string of Vanagons and one of them went through 3 of these automatics... I got fairly quick at swapping them out :crazy:
The final drive fill process I described came down from the Vanagon gods... just fill slowly until the hole just starts to weep, then use your pinky to see if you can touch the oil. Done.
O875
The PET only shows one plug on the auto's final drive so it must be a "two-way" plug.
Just a thought, if you check the level before you draw any of the old fluid out you'll have an idea of when it's "drained".
Trouble
Just completed the gear oil change in my driveway with a Harbor Freight suction pump, Fill to the fill plug was right around 1qt of Red Line Gear oil I appreciate ALL the help from you guys!!!!👏👏👏
