Ethanol Free Gas
Vito911
Has thanked: 2 times
Since the federal govt is considering allowing gas to be diluted this summer, I am considering using ethanol free 90 octane fuel. Can I add an octane boosting additive to reach a 93 octane without issues. There are a few stations in my area that offer premium octane free with octanes of 91 or 93. I currently use Shell Top Tier premium exclusively for my 991.2 C4s. Thanks.
Been thanked: 4078 times
Vito911 wrote: Fri Mar 27, 2026 5:39 pm Since the federal govt is considering allowing gas to be diluted this summer, I am considering using ethanol free 90 octane fuel. Can I add an octane boosting additive to reach a 93 octane without issues. There are a few stations in my area that offer premium octane free with octanes of 91 or 93. I currently use Shell Top Tier premium exclusively for my 991.2 C4s. Thanks.
Diluted? In what sense? Have a link? I'm lucky to live 1 mile from a gas station that sells CA legal 100 octane unleaded. But it's funny you mention ethanol-free gas. I was in my local strip-mall Ace Hardware (i.e., very small store) and was surprised to see they had a 5 gallon pale of VP 4-cycle, small engine, ethanol-free 94 octane unleaded gas. I didn't dare ask what it cost....
Has thanked: 4519 times
Been thanked: 2451 times
I think this is what the OP is referring to:
"The EPA has issued a temporary emergency waiver allowing the sale of E15 gasoline, which contains 15% ethanol, during the summer months to help alleviate rising fuel prices. This waiver will be in effect from May 1 to May 20, 2026, and may be extended if necessary."
They are relaxing the usual summer fuel mandates for a few weeks, maybe longer. Was done in the summer of 2022 and at other times too I believe.
https://www.epa.gov/newsreleases/epa-fo ... nationwide
Vito911
The Feds Plan To Start Diluting Gasoline This May: Explained
Here's what the "E15 Fuel Waiver" means, and everything you need to know about ethanol in gasoline to buy the right fuel for your machine.
ANDREW P. COLLINS
PUBLISHED MAR 27, 2026 2:00 PM EDT
87
ADD THE DRIVE (OPENS IN A NEW TAB)
Woman pumping petrol at gas station into vehicle. Hand holding a pistol or nozzle pump prepare to refuel car with gasoline.
Milan, stock.adobe.com
The biggest car news and reviews, no BS
Our free daily newsletter sends the stories that really matter directly to you, every weekday.
Email addressSIGN UP
Terms of Service & Privacy Policy.
This week, Lee Zeldin’s EPA announced “approving nationwide E15,” pitching it as “fortifying the domestic fuel supply.” What that means exactly is that the federal government will allow more stations to cut gasoline with ethanol, which, yes, makes it cheaper, but it also yields less power and worse fuel economy in your engine.
Quick Download on the May 2026 E15 Gas Waiver
Here’s a really quick contextual download for those of you wondering what “E15” means and why it’s popping up in mainstream news this week.
What is E10? Most gas in America is 10% ethanol (distilled corn alcohol) and 90% gasoline. It’s the “Standard Edition” fuel.
What is E15? It’s the “Value Pack.” It’s 15% ethanol. It’s usually about 25 cents cheaper per gallon, but because it has more alcohol, it’s slightly less powerful.
Why is there a “waiver”? Normally, the EPA bans E15 from June to September because ethanol evaporates faster than gas. In the summer heat, that extra 5% of corn juice turns into smog-forming pollution faster than standard gas.
The timeline: This waiver is in effect from May 1 to May 20. Theoretically, the condition will return to normal after that.
The catch: The government is basically saying, “We know this causes more smog, but there are wars where a lot of oil comes from, so we’re going to look the other way on the smog rules so you can have cheaper corn-gas.”
The pitch: War in the Middle East (and the prevailing war in Ukraine) has caused what the EPA is calling a “National Energy Emergency,” creating the opportunity for fuel companies to raise prices. High gas prices make Americans angry at the government, and the government doesn’t want that.
The precedent: This is not the first time an E15 waiver has been in the news—it came up in 2022, too.
The truth on the ground: Most late-model (post-2001) cars can run E15 no problem, but old vehicles don’t like it, and small carbureted engines (chain saws, mowers, boats, buggies, etc.) really don’t—it can play havoc on old seals and rubber. Use extra caution when buying gas for such vehicles to make sure you’re using what’s advertised as E10 (or E0, which is sometimes available).
‘Boutique Fuel’ and ‘Unleaded 88’ Explained
The EPA press release talked about “removing boutique fuel markets”—we’re not talking about farmers’ market fuel.
Some states (California and Illinois, for example) have special recipes for gasoline to meet local smog regs. The EPA is temporarily sidestepping that to create a “Single National Gasoline Pool” to (probably) the delight of oil companies (less work for them to do).
But no matter what state you’re in, you usually see fuel options categorized by octane, not ethanol content. “Unleaded 88″ is typically how E15 is advertised—”88” refers to the octane rating, not ethanol percentage. Because ethanol is 114 octane, that extra 5% of corn juice bumps a standard 87-octane “Regular” up to 88. So if you’re trying to avoid E15, don’t pick up an Unleaded 88 pump.
The Context for Your Car
Most of the gas you get at American pumps is E10—10% ethanol. Ethanol is the fuel diluter of choice because it’s an oxygenator. It helps fuel burn and cuts carbon monoxide in tailpipe emissions. Decades ago, we used to use lead (which turned out to be toxic), then MTBE (which poisoned groundwater). But ethanol (corn juice) works and has fewer negative societal side effects.
And ethanol does indeed help make gas cheaper. It has an octane rating of about 114, so refiners can take lower-grade gasoline, splash in 10% ethanol, and bring it up to the standard knock-resistance rating of 87 octane for regular gas. Without it, your pump price would definitely be higher.
E10 is the current status quo because that’s the most the government could get away with without the auto industry rioting. And the Renewable Fuel Standard (RFS) actually mandates a legal quota of how many billions of gallons of corn juice are sold, which also factors in.
While ethanol is cheap and abundant, it also has about 33% less energy than gasoline. By reducing the energy density of fuel, the EPA says most cars will see a 1.5% to 2% drop in fuel economy moving from E10 to E15. The reality is a little more variable. Cars.com did a post explaining the numbers back in 2018:
“Ethanol’s lower energy density leads to worse gas mileage, which is why using E85 (E85 is 85 percent ethanol) in cars with a fuel system that accommodate it is usually a bad idea,” auto editor Kelsey Mays wrote. “The math carries to E10, which has up to 10 percent ethanol. A gallon of E10 has 96.7 percent of the energy in one gallon of gasoline, according to the DOE’s Alternative Fuels Data Center.”
Ethanol is also a solvent. It’s hygroscopic, meaning it sucks water out of the air. In high concentrations, it eats through standard rubber seals, plastic fuel lines, and even certain aluminum alloys in older engines.
Some engines are tuned to run E85—even more ethanol than gasoline. There are some high-performance applications of this, but the most common usage of it is in GM’s FlexFuel engines, which have special sensors and tuning to be able to run cheap corn-flavored fuel.
But higher concentrations of ethanol start to get a lot more attractive as the price of petrol heads to the moon.
The prevailing wisdom is that E15 is safe in vehicles made after 2001—a stat you might have seen in mainstream media stories about this fuel waiver announcement. The model year 2001 is called out because the EPA and DOE conducted a 6-million-mile test on a fleet of vehicles to see where the “break point” was for ethanol damage. Those studies determined that 2001-and-newer vehicles had the hardware (fluoropolymer linings) and the software (advanced oxygen sensors) to handle the extra oxygen without “leaning out” and melting valves.
Even if your car is newer, there are reasons to be skeptical about E15. Cases in point:
The “Lean” Condition: High-performance engines (namely, anything with a turbo or high compression) are tuned to a specific air-fuel ratio. Ethanol contains more oxygen than gasoline. When the computer detects that “lean” condition, it doesn’t just spray 5% more fuel—it often has to dump significantly more fuel into the cylinder to keep temperatures down and prevent “knock” or “pinging.”
The “Closed-Loop” Lag: While cars from 2001-and-up have the brains to adjust, they aren’t always 100% efficient at it. In city driving (stop-and-go), the computer is constantly chasing the right mixture as you tip in and out of the throttle. This “hunting” for the right mix is where that extra 1% or 2% of efficiency vanishes.
Stoichiometric Hit: Ethanol burns cooler, which is great for power, but because it’s less energy-dense, you simply have to move more volume of liquid through the engine to get the same work done. For a truck towing a trailer or a sports car on a canyon run, that 1.5% theoretical drop can balloon to 4% in practice.
The thing that sucks the most about fuel science is how opaque it is. You see “up to 10% ethanol” and (usually) options for 87, 89, and 93 octane at the pump, but it’s all coming out of the same nozzle—there’s no way of validating what’s going into your tank in real time. Theoretically, we’ve got to count on federal and local regulators to keep fuel companies honest.
This article helped me understand the addition of Ethanol to the gas supply. I’m just concerned about the effect on the turbocharged Porsche engines. I can purchase ethanol free gas at various gas stations in my area but I will need an octane booster additive.
chrischrischris
Has thanked: 7 times
Been thanked: 36 times
I'm in Germany and you can buy a variety of fuels and the octane rating is shown as is the ethanol content. For the same octane rating, the E10 is less expensive than the E5. It's nice to know what you are buying and to have the ability to choose what you want.
Has thanked: 3377 times
Been thanked: 957 times
Lived in Nebraska and now Iowa the two largest producers of Ethanol and we have had choice of E-85 , E-10 and E-15 for quite awhile. All that said it is very, very common for many Gas Stations that sell " Premium " fuel to carry non ethanol blended fuel. I have run 10% blended 93 Octane for years in my Viper, race Mustangs, and now my Cayman and I can't get too concerned about it or even the addition of more choice with E-15. For over 3 decades folks worried about using ethanol added fuels and I just haven't seen any bad issues ---- worked in the Automotive Industry for 30+ years. The gaskets and seals everyone claimed would dry out or rot never occurred and though one occasionally found someone who got a bad tank of fuel and blamed it on ethanol, there were just as many incidences where it was simply regular or premium. Anymore with the detergents and other additives it seems folks are running into alot fewer issues with injectors, carbon deposits, etc. but so many are still concerned with the old issues of the past. Imho I don't think it is much of a concern and for those in a State with no choice, as there it is well known more alcohol in the fuel will get slightly poorer fuel mileage. Ironically I am amazed at the large group of younger generation track rats who convert their entire car over to E-85 with few if any problems. To a degree we are very lucky, as noted by the gentleman in Germany, to have so many choices in most parts of the US.
That article frames ethanol in a pretty negative light, so as a turbo hot-rodder who’s taken advantage of E85 over the years, a few points are worth clarifying…
From a performance standpoint, ethanol isn’t really a “diluter -- it’s more like a 114-octane shot in the arm. :angel: While it does carry less energy per volume, it significantly enhances knock resistance—which is good news for us hot-rodders.
The smog discussion is also more of a tradeoff than the article suggests. Ethanol can increase evaporative emissions in hot weather, but it also reduces carbon monoxide and other tailpipe pollutants—so it’s a mixed bag at worst. Put it this way-- even the notoriously strict California Air Resources Board supports ethanol and is pushing toward E15.
From a fueling standpoint, moving from something like E10 to E15 only requires about 2–3% more fuel to maintain the same lambda —well within the normal correction range of most engine management systems. If a setup is already that close to its limits, there’s likely something else going on. (951 hot-rodders might want to turn the fuel quality switch to add 3% fuel overall—primarily for full-throttle fueling where the closed-loop system doesn’t operate, but likely fine either way. More modern cars should be able to adapt/handle it on their own.)
Ethanol can be harder on certain fuel system components—especially those not designed for it—I can attest to that. But going from 10% to 15% is unlikely to move the needle much in that regard. Jumping to 85% is a different story.
Vito911
I may occasionally fill up with a tank of Ethanol free and add a reputable octane booster additive. Just to make me feel better.
Thanks for your insights and I appreciate you sharing your experience as a hot rodder😎
944m3
Has thanked: 25 times
Been thanked: 100 times
Good reading. Might be a good reason to add a flex fuel sensor to my standalone.
Friend sent me this today... Much cheaper than California gas, but at 87 octane I'm not sure there's much upside...
