944 A/C Delete, Belt Adjustment Bracket
Been thanked: 4078 times
With huge thanks to @NYFlapjack2, attached is an STL file, and a STEP file, for a small bracket that allows you to delete or decouple the A/C compressor on a 944 without relocating the alternator, and without losing the ability to tension the alternator-only belt. Genius. :)
A pdf guide showing how to use the bracket is posted here:
viewtopic.php?f=19&t=498
944 AC delete bracket.STL
944 AC delete bracket.STEP
