Hoosier's new A8, will a 275/30/18 fit?
- Has thanked: 3379 times
- Been thanked: 957 times
I figure someone on here will be trying the new A8/R8 reasonable soon and I am wondering whether a 275/30/18 might fit on a Cayman/Boxster GTS with 9 inch front wheels. The reason I am asking is that the new tire no longer has a 255/35/18 and they fit fine on the front, even with just camber plates. The specs on the 275/30 are almost identical but many of us have found over the years that there can be discrepancies in what is listed by Manufacturers. I am not worried about the 295/30/18 since I was running them in the past with the A7. I imagine an autocrosser might answer first and there are some folks already using the new tires and I hope they post their impressions on this site. Thanks for reading and if the new tires are as sticky but last a bit longer many of us will be happy since Purple Rubber is X-pensive!!!!!
- J-Dub
- Has thanked: 663 times
- Been thanked: 573 times
I have not experienced the A8 myself however I will keep an eye out for others at the track days and report back any info I come up with.
Jeremy
Jeremy
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
Have run Hoosiers on an off for years and am hoping the A8/R8 are as much of an improvement as the A7/A7 were over the previous 6 model. With the highs having been single digits for the past few days in the Midwest I figure someone in a warm clime will try a 275/30/18 earlier than those around here so I figured why not drop a line with all the friendly folks at Carpokes?
Thanks for the response J-Dub as well as all your help in the past.
