Another Door Card Repair Thread
PSU_Crash
Has thanked: 190 times
Been thanked: 111 times
On par with most of this car, the driver's door card had been treated with a heavy dose of ignorance and incompetence. Or perhaps a guy just telling the shop "Make it look good for pictures"
To start with, the switch surroundings were all but non existant. Not my first rodeo. Grab the fiber glass.
Of course all of the plastic clips had been pulled through and all but one were missing. I bought all new clips.
Round one with mat to build up where I removed a lot of the falling apart card material. A little cloth too.
After this was fully cured, I went back with a product called Fibral to recreate where the metal cips used to be. That part of the car was completely gone once I trimmed out all of the bad. A little grinding and sanding, then another layer of cloth.
From the from other side
On the the torn out clip locations. I just used fiberglass resin with no cloth on these spots. In hindsight, maybe not the best idea. It did substantially increase the rigidity and seems to have glued all the fray back together.
Seems I accidentally deleted the pics of this all cured up before install. Speaking of install...
Before putting the car on, I had to address the missing vapor barrier. 3M MWUR9 widow weld butyl ribbon to the rescue. As well as some 6mil dropcloth. A lot of the door was very tacky from the original barrier still, so that helped out with not needing a lot of the butyl ribbon. The 1/4" round butyl was stretched thin and "skillfully applied". Then rolled over the bead/plastic to get a solid seal.
Now for the real fun!
Placing the doorcard back on and realizing that I don't really know what I'm doing. That metal arm on the backside of the top armrest mout was the first combatant. Once I realized it actually slides into the door frame that was step one. As well as beer time while I scratched my head.
I bought this hardware kit off Ebay from a German seller. (I didn't know that when I bought it) It took about 3 weeks to be delivered, but so far had everything I needed as well as a couple pages from the PET (in German) and all parts nicely bagged and tagged.
Here's a link to the listing for anyone interested https://ebay.us/m/bLB4eL
After that I thought I was golden! Until I tried to mount the card. The 2 front most screws did not line up with a hole in the door. There wasn't even a hole within inches. Well, there is now. Maybe another late/early difference? I already know the door has been replaced so who knows what it is actually off of.
The next problem was the pocket in the bottom of the door. It was too big to fit in the recess in the door frame. this held the bottom of the card way off the metal frame. No way I could get the rest together like this. You can see where it is pushing in on the front side of the pocket.
Removed the card and took measurements. Definitely not going to fit. A little percussive maintanance persuasion in that area of the door card was the solution. I know .. not ideal. In the end no one will ever know once the lower pocket is reinstalled.
I thought the fight was over and I was grabbing another cold one in celebration. Too soon ..
3 of 4 holes in the bottom of the pocket trim piece line up with nothing and I'm missing the little block in the front of that pocket piece that screws to the door and to the trim. Time for the parts car's first donation :D That's today's mission.
Anyways, at this point it was time to get the switch panel installed and test that all of that still works. I'm not sure if I have the wiring harness correct. Obviously I have something wrong here. It is pushing on the switch from the back with some pretty good force. I tried moving it around and tucking it a few different ways. This easily clipped into place and were much more flush on the bench.
Any advice there? I'm sure this is installer error somewhere :?
After all of this I now have all windows and mirrors working for the first time!!! So I had to go for a quick mountain run yesterday. 8-)
944er
Has thanked: 13 times
Been thanked: 54 times
Nice job. Especially like the replacement water barrier, that's smart thinking.
PSU_Crash
944er wrote: Mon Jan 19, 2026 5:43 pm Nice job. Especially like the replacement water barrier, that's smart thinking.
Thanks! Anything to keep some moisture away from the door car!
Much to my dismay, I did end up slitting the barrier for the speaker to fit. In hindsight I should have used the heat gun and pressed the speaker in. Next time.
barnwerks
Been thanked: 36 times
Great effort :clap: Glad you got everything working.
It seems you are close to understanding the mis fit of the door interior bits. I can confirm you are fitting a late door panel to an early door. You may have also noticed the wiring port bellows at the jamb are smaller on the early door.
Regarding the vapor barrier, if you study an original, you'll notice they have drip (flashing) panels that conduct water back into the door cavity. Without these the water collects at the bottom of the plastic, weeps through the push fastener perforations and will saturate the door card very quickly.
PSU_Crash
barnwerks wrote: Mon Jan 19, 2026 8:48 pm Great effort :clap: Glad you got everything working.
Yes! I did notice the bellows and just thought that's a tight fit. Seems like it's ok now. Since the original plastic was gone, I had nothing to model after. Sounds like a flap on the inside to divert the water. That makes sense. Probobaly why the bottom of the card had obviosly been wet. I'll have to look up some stock pictures and decide if I want to take it back apart. Speaking of drainage, there doesn't appear to be any drain holes in the bottom of the door. Maybe they are hid by the seal?
Paint work is definitely in my future and I have a parts car that should have the correct door. It's been added to the list 😄
EuroFighter2003
Has thanked: 20 times
PSU_Crash wrote: Mon Jan 19, 2026 8:50 am Anyways, at this point it was time to get the switch panel installed and test that all of that still works. I'm not sure if I have the wiring harness correct. Obviously I have something wrong here. It is pushing on the switch from the back with some pretty good force. I tried moving it around and tucking it a few different ways. This easily clipped into place and were much more flush on the bench.
I have this exact same issue after reinstalling my door card. I will include a few pics here when I can. For me I am not certain if it is an issue with the electrical connectors pushing out, or if the actual door card bowed out at some point, causing the "drooping" window switch look.
The 3D printed part that @Tom made for me did help to solidify this area so that I could at least reinstall the window switch, although I still have the drooping issue that you mentioned and pictured above.
PSU_Crash
EuroFighter2003 wrote: Fri Jan 23, 2026 5:49 am I have this exact same issue after reinstalling my door card. I will include a few pics here when I can. For me I am not certain if it is an issue with the electrical connectors pushing out, or if the actual door card bowed out at some point, causing the "drooping" window switch look.
Test fitting the switch assembly on the bench it was nice and flush. It required some effort to get in with the wiring attached, so I'm confident it's something with the wire routing. I replaced the entire harness. It could be anything :? If you figure out what's goin on please let me know!
