944 Power Door Lock Actuator
The 944 power locks are actuated with plastic pieces that are prone to failure. The originals are cheap and still available, but if you need one in a pinch, I've modeled a 3D print version based on the original. (Original is white; 3D printed version in gray). Best if printed on a high-rez resin printer.
944 Door Lock Lever.stl
