Oil Filer Port Block-Off Cover
Been thanked: 4080 times
Here is a cover for the oil filter port on the 944. It probably works on other cars too, but it was designed and tested on the 944. The gasket is only needed if you plan to spray cleaning fluids and want a water-tight cover. Be aware that Brake Cleaner will dissolve ABS, so choose your plastic wisely if you plan to use any acetone-based cleaners.
Oil Filter Port Cover Body.stl
This is the basic cover. It prints without supports and can be used without the other files to block off the port.
Oil Filter Port Cover Logo.stl
For printers with multi-color capabilities, this is just the CP logo shown in red in the video below. On Bambu printers, just import this file and the file above at the same time and click yes to say it is a single object with multiple parts. Then select which filaments/colors you want for each.
Oil Filter Port Cover Gasket.stl
This is the gasket you can print in TPU to help create a water-tight seal for cleaning.
