Thanks to Tom for posting the detailed dash removal PDF instructions. I'm planning on undertaking this project after the driving season is over here in central PA.
I need to have the small dash cracks repaired or the dash recover. Is there any recommendation on who to send the dash to or other DIY options? Also while the dash is out are there any other recommended preventative maintenance item to take care of?
John
86' 951 Turbo
Dash crack repair or recover
- Has thanked: 4604 times
- Been thanked: 2498 times
Here's a thread showing what one of the Carpokian wizards here did to repair his dash.
viewtopic.php?t=3030&start=50#p40720
Actually, the entire thread ('Father Kid 944 Project') is excellent regarding not only the dash rehab but the whole process a father & son undertook with a 944.
Just Dashes in California does great work, but it's pricey. A good local auto upholstery shop can also do it.sabres32 wrote: Sun Oct 12, 2025 7:12 pm Thanks to Tom for posting the detailed dash removal PDF instructions. I'm planning on undertaking this project after the driving season is over here in central PA.
John
86' 951 Turbo
While it's out, replace all the vacuum lines and check the heater core for leaks. It's the perfect time.
- Has thanked: 961 times
- Been thanked: 4160 times
Also a good time to replace the crumbling foam on the heater console flaps...
viewtopic.php?t=326&start=10#p3181
Thanks to everyone who replied. After addressing oil leaks, installing new oil pan gasket, motor mounts, hoses, turbo rebuild etc it's time to get the front end alignment done and move on to the dash this fall.
I'll add to foam for the vents to my list. If anyone think of other restoration once the dash is out please let me know.. at least the 944 does have all the actuators and vacuum solenoids like my 928s did when I restored those cars
John
John
