Only944 shifter
In my process of refreshing all the transmission components in my car, I stumbled across the Only944 short shifter. While I want to keep the stock throw, I do like how crisp the new kit looks. I was thinking if enough other people have the same dilemma I have, maybe we could have Only944 start selling a stock throw shifter kit. Let me know if you guys are interested, if enough of us are I’ll send an email to Kyle
‘83 Platinum N/A 944
Black944 turbo
- Has thanked: 14 times
- Been thanked: 127 times
I have an old welt meister and on the longer setting it is pretty much exactly like stock. Might want to look for a used one of those.
- PSU_Crash
- Has thanked: 192 times
- Been thanked: 111 times
FYI I recently replaced my shifter with his short throw and all the linkage. Zero regrets!Poorsche44 wrote: Mon Sep 22, 2025 1:08 pm In my process of refreshing all the transmission components in my car, I stumbled across the Only944 short shifter. While I want to keep the stock throw, I do like how crisp the new kit looks. I was thinking if enough other people have the same dilemma I have, maybe we could have Only944 start selling a stock throw shifter kit. Let me know if you guys are interested, if enough of us are I’ll send an email to Kyle
I know, that doesn't help your cause, just my $.02
'86 Zermatt Silver 944 N/A
How much did it reduce the throw in your car? Since I don’t take my car to the track I’m not worried about fast shifting or anything like that, but I worry about mis-shifting more with a short throw
- walfreyydo
- Has thanked: 29 times
- Been thanked: 58 times
I have the Only944 short throw shifter kit and I wouldnt say it makes the throw that much shorter. Ive driven other cars with an extremely short throw and its no where near that.
I think overall it was a nice upgrade and what I noticed right away was an improved feel of the shifter and much less play in the shifter. I replaced both the shifter shaft in the cabin and installed the short throw linkage on top of the trans. The two definitely go together. I recommend that Loctite be used on the 10mm bolt that connects the shifter rod shaft coming out of the trans to the short throw linkage.
Garage
Garage
- Gaspowered
- Has thanked: 297 times
- Been thanked: 84 times
Here's a good video on the Only944 kit. He goes over exactly how much the throw changes.Poorsche44 wrote: Mon Sep 22, 2025 5:17 pm How much did it reduce the throw in your car? Since I don’t take my car to the track I’m not worried about fast shifting or anything like that, but I worry about mis-shifting more with a short throw
Brian
'88 944 Turbo S / Silber Rosa
- PSU_Crash
My old linkage was completely SHOT with several inches of play in all diirections while in gear. So I can't say how much it reduced the throw, but I will tell you it's night and day difference.Poorsche44 wrote: Mon Sep 22, 2025 5:17 pm How much did it reduce the throw in your car? Since I don’t take my car to the track I’m not worried about fast shifting or anything like that, but I worry about mis-shifting more with a short throw
The video in the post above shows all you need. Just do it and never look back
Okay, you guys have convinced me to get the short shifter. Can anyone tell me if the shift linkage rod has made any improvements as well? I might as well do that while I’m in there, but if it doesn’t change the feel at all I’ll leave it.
- walfreyydo
You can redo the shifter rod itself yourself with parts from McMaster Carr (some washers, a few roller bearings and a bolt). There is some thread(s) on rennlist about it, which is what I did. I think it works just as well as the only944 replacement, but if you dont want to mess around with that, just go with the only944 option.Poorsche44 wrote: Tue Sep 23, 2025 4:16 pm Okay, you guys have convinced me to get the short shifter. Can anyone tell me if the shift linkage rod has made any improvements as well? I might as well do that while I’m in there, but if it doesn’t change the feel at all I’ll leave it.
Garage
Garage
