Plugs - To change or not to change
Been thanked: 667 times
In a few months I’m due for my four year service for my 2022 718 GTS 4.0. I only have 13,000 miles on the odometer. The dealership says that my spark plugs need to be changed because it’s four years. My independent shop told me that I can wait until 30,000 miles to change the spark plugs. I’m not sure if I should have the plugs changed. Thoughts? Recommendations?
Thanks!
Been thanked: 4015 times
I just had mine changed in the turbo at 8500 miles, during its 4 year servicing. The tech said the plugs would last much much longer but Porsche wants them changed every 4 years so they won't corrode and seize in the threads. I don't know how likely that is in general, and especially in Los Angeles.... Many car makers set ridiculously long spark plug intervals these days so they can advertise how the car doesn't need a tune-up for the first billion miles, so I kind of doubt Porsche would recommend short intervals unless there was 'something' behind it.
J-Dub
Has thanked: 654 times
Been thanked: 567 times
I changed mine in my GTS 4.0 6 months ago. I thought it would be sort of a write of passage to change my plugs, still getting to know the car. I think the OG plugs looked great, no oil, no buildup, not signs of running strange and no corrosion. That being said, they recommend every 4 years and I don't have any compelling evidence to suggest to you one way or another.
Good Luck With your Decision.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
Has thanked: 4454 times
Been thanked: 2417 times
My choice is to follow what Porsche recommends just because, well, Porsche. :angel:
Has thanked: 3304 times
Been thanked: 942 times
Ja, Porsche sayzz, sew ve moost du itt! Agree with blue, what the heck, and likely after 4 years also a good thing to check as preventive maintenance.
WillyDaP wrote: Mon Jun 09, 2025 1:36 pm Ja, Porsche sayzz, sew ve mosto du itt! Agree with blue, what the heck, and likely after 4 years also a good thing to check as preventive maintenance.
Good point on the preventative - a chance for techs to take a gander at things in addition to the benefits of the new sparkys.
I will add that Porsche is fairly adamant on changing the plugs and doing all the other service per their maint schedule. Porsche also doesn't care whether it's low miles or not. They want things done at whichever comes first - miles or the time.
Porsche techs and most good independent Porsche mechanics will also generally say the same. Following the schedule is never a wrong choice.
There's also the Karma thing............................. :mrgreen:
Has thanked: 1047 times
Been thanked: 618 times
Larry C wrote: Mon Jun 09, 2025 7:23 am In a few months I’m due for my four year service for my 2022 718 GTS 4.0. I only have 13,000 miles on the odometer. The dealership says that my spark plugs need to be changed because it’s four years. My independent shop told me that I can wait until 30,000 miles to change the spark plugs. I’m not sure if I should have the plugs changed. Thoughts? Recommendations?
Thanks!
Change them, that is what I have seen elsewhere.
Would be Too much risk for my tastes not too, it’s the seizing thing.
Thank you all for your responses. The plugs will be changed!
Arne2
Has thanked: 10 times
Been thanked: 218 times
I changed mine at 27k miles, 4 years after in-service date. That was actually 5 years from build. (The car sat unsold at the dealer for almost 10 months after delivery.) Mine came out OK, but they seemed to have early signs of corrosion in the threads. So the 4 year limit seems like a good idea to me.
- Arne
Past Porsches:
  • 1972 911T coupe, silver
  • 1973 914 2.0, Saturn Yellow
  • 1984 944, silver
ReidMcT
Has thanked: 142 times
Been thanked: 190 times
P_Coastal wrote: Mon Jun 09, 2025 2:51 pm it’s the seizing thing.
This.
I had a very scary time removing almost-seized plugs that the PO had not changed on time, despite low mileage. This was on a 2L 718, so not perfectly comparable.
ReidMcT
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
