944 Visor Clip STL
Been thanked: 4087 times
Here is my STL for a 944 sun visor clip. I should be printed on its side as shown below, so the hook can flex without snapping between layer lines. Printed on its side like this, it's strong like ox. It's styled closely after the original, but with no washer slot, to make it easier to print. Unless you get out a flashlight as study it, it will pass as an original when printed as shown. You can scale the print (99%, 101%, etc.) if needed to get the perfect clipping action.
944 Visor Clip.stl
Has thanked: 527 times
Been thanked: 270 times
Thank you for yet another item that helps the 944 crowd.
There are quite a few out there, but I always like to make parts that look like the factory part. And I didn't want to drive around for a week or more with the visor flopping into my head. :)
