Glossary of Acronyms
Been thanked: 4093 times
Someone on FB asked for a glossary of all the acronyms that get tossed around when talking about the 951, so I thought I'd add that to the technical download section. I've come up with this list so far. What am I missing?
AFM
AFR
BOV
CC
CV
DME
ECU
EMS
FPR
ISV
KEP
KLR
LBE
LR
LSD
MAP
MBC
MAF
O2
OBD II
PP
TB
TPS
VEMS
VR
gruhsy
Has thanked: 48 times
Been thanked: 83 times
OBD2…..Ftech9 9 DME’s
gruhsy wrote: Sat Feb 05, 2022 10:12 am OBD2…..Ftech9 9 DME’s
Thanks, I added FPR too. I'm going to let it sit a bit, I'm sure there are more....
Cyberpunky
Has thanked: 34 times
Been thanked: 10 times
some have multiple acronyms like ISV is also referred to as ICV.
EBC is another to add
It seems a lot of Noob's are now referring to the DME relay as the DME which I find both confusing and annoying, although I am not sure what can be done about this trend. It's 1 word. 5 letters, but it seems typing relay is too hard and in fact I think they think it makes them sound less noobie'ish and like they know what they are talking about when it actually does the opposite
Bruce
N2MY951
OPRV
N2MY951 wrote: Mon Feb 07, 2022 6:14 amOPRV
Good call. Will add that one and a few others on the next update. The glossary now includes:
951, 951, AFPR, A-Tune, AFM, AFR, APE, BOV, CARB, CC, CP 8-), CV, CO, DME, ECU, EBC, EGT, EMS, FPR, HC, IC, ICV, ISV, KEP, KLR, LBE, LR, LSD, MAP, MBC, M-tune, MAF, N/A, NOx, O2, OBDII, PCA, PCNA, PP, PPM, ROW, TB, TDC, TPS, VEMS, VR, WOT
Will be adding OPRV, NTC, KW, PWM, TT, HVAC, BS, 9201, TB, 920Xv6.2.
What else?
gruhsy
FD ratio
gruhsy wrote: Mon Feb 07, 2022 9:06 amFD ratio
Final Drive?
gruhsy
Lol
Yep
N2MY951
ET - offset
