Cubby below radio
Damo
Has thanked: 17 times
Been thanked: 8 times
I've had my 85.5 944 a few months now and it only had a blank panel below the radio. I've seen there's meant to be a storage cubby there so I designed this and printed in in PLA for extra storage. Since taking the pic I've added some black felt (as used in jewellery boxes) to the lower surface to stop thinks sliding and rattling.
The area below my radio had been monkeyed with so if this doesn't fit in our car let me know if anything fouls and I'll edit the design.
Attached the STL file and an Autodesk Fusion export.
Cubby under radio.stl
944 cubby under radio.f3d
TerrorBytes
Been thanked: 9 times
I would suggest using ABS or ASA. PLA will easily soften and deform if left in a hot car
Damo
Yep good point. I only have PLA and not sure if my printer could handle ABS or ASA reliably - it maxes out at 240 degrees C. Do you think it would be worth trying @TerrorBytes ?
redpanda86
You'll need a printer with a decent heated bed and ideally a heated chamber. I print ABS all the time with no issues since my printer can accomodate these requirements
andiparker
Would it be possible to share the original CAD file so i can use it as a basis for a combined cubby and boost gauge plate.?
Has thanked: 933 times
Been thanked: 4002 times
andiparker wrote: Sun Aug 10, 2025 6:27 pm Would it be possible to share the original CAD file so i can use it as a basis for a combined cubby and boost gauge plate.?
Like this?
This one is kind of complicated as it used an FDM printer for the plate and a resin printer for the cubby (which is printed in 2 or 3 pieces and screwed together so that it could be felt-lined).
I have a good STL for the panel that I'll post tomorrow. It has stand-off in front of the screw holes, which allows it to screw in tight without going getting pinched in at the bottom like most of the online STLs...
andiparker
Tom wrote: Sun Aug 10, 2025 7:56 pm
Like this?
That's pretty much identical to what I had in mind. Appreciate you sharing !
Damo
What CAD program are you using? I'll often import STLs into Autodesk Fusion and then convert to a solid to modify. Although Tom's model looks better for your needs anyway :)
andiparker
Damo wrote: Tue Aug 12, 2025 11:19 pm
Thanks - I’ve just converted across to fusion and see that it can work with STL files so I have everything I need when combined with Tom’s plate too. Thanks for all the help.
angrymancunian
Damo wrote: Sat Mar 15, 2025 4:04 pm I've had my 85.5 944 a few months now and it only had a blank panel below the radio. I've seen there's meant to be a storage cubby there so I designed this and printed in in PLA for extra storage. Since taking the pic I've added some black felt (as used in jewellery boxes) to the lower surface to stop thinks sliding and rattling.
Any Chance you have the design files for the cubby?
