2002 Porsche 996 Turbo
Tazio Nuvolari
Battery replaced awhile back. Portions of the AC-heater numerals disappeared. Recently the odometer totally disappeared. Nor able to restore it. No Owner's manual available. Help !
You probably have a bad LCD panel. It's common enough that kits exist to fix them...
https://914rubber.com/986-and-996-clima ... cement-kit
Odometer has its own display, and either has a bad LCD or something wrong with the circuit that drives it. Either way, you'd need to remove it to diagnose. If it's the LCD, there are kits for it too. See video below.
