I put a lot of effort into making the gauge panel fit well to start. Spoiler alert, a flat panel can't/doesn't sit flush against the frame if you look closely. Will post more details on that, and these STL files, soon, along with files for more basic gauge configurations.
Gauge Panel with Cubby
- Has thanked: 961 times
- Been thanked: 4160 times
Yet another detour as I clean up wiring. As part of my new back-to-basics kick, I didn't want all the USB outlets and gauges under the radio that I had till now -- just the Zeitronix Wideband/EGT/boost gauge. At first I made a panel just for that gauge, but the plate ended up looking so blank that way. So after a lot of trial and error, here's the latest. It's the Zeitronix gauge with a custom bezel, along with a half-sized cubby inspired by the 968, and a little Carpokes shout-out for good measure. All the custom parts are 3D-printed, though the gauge bezel and matching trim on the cubby were done on the resin printer, and cubby is felt-lined -- all so it doesn't 'look' like 3D-printed parts.
Zirconocene
- Has thanked: 81 times
- Been thanked: 53 times
I don't know @Tom, I think you need to label these posts more carefully. That little glimpse into your interior is very, very NSFW. Between the clarity of the pod, the lovely stitching on the trim, and that wheel...whew!
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
I'll work on that for sure.Zirconocene wrote: Wed Jan 29, 2025 12:48 pm I don't know @Tom, I think you need to label these posts more carefully. That little glimpse into your interior is very, very NSFW. Between the clarity of the pod, the lovely stitching on the trim, and that wheel...whew!
- P_Coastal
- Has thanked: 1072 times
- Been thanked: 640 times
Well done Tom, looks greatTom wrote: Tue Jan 28, 2025 7:57 pm Yet another detour as I clean up wiring. As part of my new back-to-basics kick, I didn't want all the USB outlets and gauges under the radio that I had till now -- just the Zeitronix Wideband/EGT/boost gauge. At first I made a panel just for that gauge, but the plate ended up looking so blank that way. So after a lot of trial and error, here's the latest. It's the Zeitronix gauge with a custom bezel, along with a half-sized cubby inspired by the 968, and a little Carpokes shout-out for good measure. All the custom parts are 3D-printed, though the gauge bezel and matching trim on the cubby were done on the resin printer, and cubby is felt-lined -- all so it doesn't 'look' like 3D-printed parts.
I put a lot of effort into making the gauge panel fit well to start. Spoiler alert, a flat panel can't/doesn't sit flush against the frame if you look closely. Will post more details on that, and these STL files, soon, along with files for more basic gauge configurations.![]()
- Darwin
- Has thanked: 116 times
- Been thanked: 74 times
If you're selling these, I'm down to buy one! I have two gaping holes where I used to have two other gauges. I have a 968 cubby I had planned on basing a design of off but I have yet to have the time.
Money in hand! lol
Money in hand! lol
2012 VW Tiguan - Kinda stock
What gauge do you want to run in the panel? The hole in my panel needed to be 52mm for the Zeitronix, and I'm not sure how standard that really is....
- chris white
- Been thanked: 175 times
oil pressures a little low.....
Garage door was closed, so motor wasn't running....
- chris white
Well your tach is low too…..can I interest you in a new restomod 944?
