Step 11. Removed hoses on receiver/drier to remove/replace it -- connections are 19mm, counter-held with 17mm; undid bracket with 8mm wrench. Note the “IN” side goes to the green sensor/switch toward the front of the car. Will need new o-rings here too. (All supplied by Griffiths if you get their parts.)
- receiver.jpg (149.87 KiB) Viewed 2923 times
Step 12. Loosened receiver-drier bracket (8mm socket) and slid receiver-drier out of car. Removed bracket from frame to clean it and frame rail. New receiver-drier is 60mm diameter, whereas old/factory one (and bracket) is 67mm. Griffiths supplies a foam tape to fill the gap, which seemed a little sketchy to me. I fabricated aluminum spacers (look like crank bearings) so go around new receiver-drier and fill the gap.
- receiver fillers.jpg (124.11 KiB) Viewed 2923 times
I'm sure the foam tape would have been fine, but for how long?
Step 13. The caps on new receiver-drier were holding pressurized nitrogen inside to keep it dry, so left the caps on until the last minute. Idea is to keep air/moisture as much as possible until just before you charge it. Condenser was also pressure filled. Pull off those caps and reconnect as the last thing before pulling a vacuum on the system.
Step 14. Reinstalled receiver-drier bracket – now clean – and put new receiver drier in place with spacers but without hooking it up.
Step 15. Removed lower hose at bottom of condenser (19mm wrench, 17mm to hold fitting). Removed M6 nut securing that hose/line to side of radiator support. Removed two M6 bolts holding condenser mounts to car, with spring washers and fender washers. (Yes, two little bolt hold it in the car!) Wiggled condenser down and out of car. Rubber strips the condenser sits against are perished – need replacements. The upper front side of the condenser fins were all folded over by maybe ½”. Looks like the speedforce racing intercooler is a smidge too big and smashed the top of the condenser. The Griffiths condenser is a tiny bit shorter, so was able to adjust the intercooler just enough to fit the condenser without interference or altering anything.
- 35-yo-seals.gif (1.21 MiB) Viewed 2923 times
"Air guide seals" between condenser and radiator were shot. Every little thing helps, so I had to track down new ones.
- new-seal.gif (850.2 KiB) Viewed 2923 times
And here it is all cleaned up with the new seal, part number 94402511500. When I ordered the seal, I order "2", and for whatever reason they sent me a 10-12ft length of it. If you need any, let me know. I suspect it's the only supply outside of Germany.
- condenser-mounts.gif (1.03 MiB) Viewed 2923 times
After the lines are removed, the condenser is held in place with one M6 bolt on a rubber isolator, on each side.
Step 16. Removed the Schrader valves from both service ports on the driver inner fender and installed R134a conversion fittings (blue on low-side, thick hose). Installed to goodntite spec with open end wrenches after oiling the o-rings inside with a little oil from the new compressor. My calibrated arm was off, and I had to go back later and really crank them down to eliminate all leaks. The kit I bought came with a little tool for removing the Schrader valves -- they just screw out, but getting a grip on them without the tool is a challenge.
Step 17. Installed the refrigerant line manifold (elephant-face) from the old compressor onto the new compressor. Used the black o-rings (4) that came with the compressor (which were pre-oiled). Used the new Allen bolts that came with the compressor and torqued them to 18 ft lbs in a star pattern.
Step 18. Filled compressor with oil. Used the Auto 100 Ester oil Griffiths supplied. Can’t mix dissimilar oils, so relied on Griffiths to supply this universal donor oil. Made a dipstick and poured 5/8ths of the bottle into the compressor’s suction port (marked S) using a funnel. That gives me 5 oz of new oil (since the can holds 8). That was based on Griffiths saying to add 3 oz for new compressor, 1 for new condenser, 1 for new hoses, 1 for drier, but not more than 6 total. Since the evaporator and long line to firewall were not flushed, I opted to pull up short of the full 6 oz. There's no good way to measure the residual oil in the system, so you need to make an educated guess. Put plugs in port openings and put compressor back in car, finger tight, using the factory M10 and M8 bolts front and back.
Step 19. Re-connected to spade connector for the compressor clutch to the factory connector. It is a tight connector, so I had to shove it from the back of the terminal pin with a screwdriver to get it to seat all the way.
Step 20 . Installed new Griffiths high-side hose on compressor (the hose that goes to the condenser). Used o-ring supplied by Griffiths with a little ester oil on it. Cleaned off all the microencapsulation crud on factory bolt and used blue locktite on it. Torque it to 18.5 ft lbs. (Spec might be a tad higher, but with locktite it didn’t seem necessary – 18.5 was plenty snug.)
Step 21. Re-installed low-side hose on compressor (the one that goes to firewall). Used NOS Porsche o-ring I had “in stock” from last time I re-sealed the lines, with a little ester oil on it . The one Griffiths supplied was probably fine but the cross-sectional diameter was maybe a quarter to a half mm smaller. Cleaned microencapsulation crud off factory bolt and used blue locktite. Torqued bolt to 18.5 ft lbs. [In hindsight, probably should have used Griffiths o-ring since they are 134a friendly.]
Step 21. Put A/C-Alternator belt back on pulleys. Tensioned it to 9.5+ per manual on the 9201 tool (though maybe not a full additional turn, since that always feel "too" tight to me). Torqued M10 and M8 compressor mounting bolts to 33 and 17 ft lbs, respectively. Torqued turn buckle jam nuts to guttentite spec. Torqued turnbuckle mounting bolts, M10 and M8, to 33 and 17 ft lbs, respectively. Put yellow torque paint on bolts.
Step 22. Put power steering belt on pulleys. Tensioned it to spec (5mm of deflection). Torqued M8 pump mounting bolts to 17 ft lbs. Torqued turn buckle jam nuts to guttentite spec. Torqued turnbuckle mounting bolts to 17 ft lbs. Put yellow torque paint on bolts.
(continued next post)
