Harness Omega Clips
Has thanked: 943 times
Been thanked: 4028 times
Here is an STL for an Omega clip sized to fit the Kroon harness nicely on the 944. I couldn't find a factory clip that fit as well as I'd like, so made this once exactly the size needed. Given the hot environment, it's best to print in a high temp plastic like nylon-cf.
Omega Clip for Kroon 944 Harness.stl
The red one in the middle is 3D-printed. The others are all factory clips.
