New to the forum introduction
Polarcito88
Hi, I just joined this site and wanted to introduce myself. I have admired Porsche's since I was young and finally In April of this year I bought my first one, a 1982 911SC 3.0 pictures here below. I was planning on replacing the fuel filter and other routine maintenance and cam across this broken wire located on the driver's side of the engine compartment, below the fuel filter. Can anyone tell me what this wire is for. Thank you.
Carmagic
Has thanked: 33 times
Been thanked: 275 times
Welcome to the 911 club !
That's the connector for the oxygen sensor. I had the same on my 82. I made a new piece with the 3D printer when I had the engine out the last time. It must have being there for a while.
Engelbert
Polarcito88
Engelbert, thank you for your response. Will this O2 sensor connector being broken prevent the car from starting ?
Carmagic
Polarcito88 wrote: Thu Nov 28, 2024 7:35 pm Engelbert, thank you for your response. Will this O2 sensor connector being broken prevent the car from starting ?
Looks like only the plastic piece is cracked and the wire is still OK. If that's correct, you could just use some tape and fixit so it doesn't worse, until you can repair it properly.
Engelbert
