944 Turbo Head Gasket Replacement Procedure
- Has thanked: 961 times
- Been thanked: 4160 times
Here is downloadable PDF of the 951 head gasket replacement article I first did in 2006. I updated it a bit and added a few additional tips. I hope you never need it.
Thank you for the PDF!
Im thinking that the head gasket may be good. The mechanics that came to help me one day told me it looked like the had gasket was good. The spark plugs were not steam cleaned and looked like they had normal wear. It also had techron in the gas tank and marvel mistery oil in the oil which also may be causing it to smoke. It need the fluids changed asap and some fresh fuel. Im going to drive it around the block to see what works. The car moves and the fluids are all there. No sign of over heating.
