944 TDC Window Block Off
Been thanked: 4015 times
I had to pull the bolts for my bellhousing grounds today and didn't want them dropping into the TDC window directly below, so made this little block off plate. It just plug into the bell housing window loosely and makes sure nothing can fall in there. Good thing too -- I dropped a bolt and a washer and both landed right on this plate!
944 TDC Window Block Off.stl
