I recently followed this procedure viewtopic.php?t=341, which BTW was the main reason I joined CarPokes.
I was going to take the dash to a local upholstery shop but was a bit disillusioned when the guy said he would just cover over the top of the existing very cracked plastic. He also suggested they would need to cut some sort of aluminium strip to finish the demister holes in the top of the dash. At this point I decided to do the recovering myself. The demister holes did look a bit dodgy so I designed and printed a piece of trim to slot into the holes to finish things off a bit better. With the limitations of my printer I divided the piece into 6 parts, printed them and then glued together with super glue.
I'll add the stl files in the next post
944 Dash Demister surrounds
markagsmith5
- Has thanked: 9 times
- Been thanked: 30 times
1987 944 Turbo
2024 BYD Seal Premium
markagsmith5
This is the complete left half if you have a printer large enough
Otherwise here is the left side in 3 pieces
This is the complete right half if you have a printer large enough
Otherwise here is the right side in 3 pieces
1987 944 Turbo
markagsmith5
The 3D model of the LHS in OpenSCAD
LHS part 1
LHS part 2
LHS part 3
RHS is just a mirror of LHS
1987 944 Turbo
