Phone mount fitted
grasmere
Has thanked: 131 times
Been thanked: 72 times
Following JetFuelOnly recommendation and video I took the plunge and ordered a mag phone mount
for left side of my RHD UK 718CS.
Took all of 5 mins to fit and it’s really good, beautiful fit and solid, not cheap but less than the car 🤣
Gotti of the Deep
Has thanked: 19 times
Been thanked: 13 times
grasmere wrote: Sat Aug 31, 2024 6:17 am Following JetFuelOnly recommendation and video I took the plunge and ordered a mag phone mount
This won't work if the phone has a case, correct?
2024 982 CS Shark Blue, 6spd MT, SC, PASM, PTV
Spec'd like it won't be made anymore.
Has thanked: 1072 times
Been thanked: 639 times
Gotti of the Deep wrote: Tue Sep 03, 2024 7:16 am
If we are talking iPhones, the case should say if it is MagSafe compatible.
3MOS
In case it's helpful - this is the Anima Motorsports (https://animamotorsports.com) mount. I installed one also and it's well made and seems very solid. I'm going to use it for a Catalyst instead of a cell phone, but same 1" ball mount will let you do either as well as leverage anything else that uses a standard 1" ball mount.
