Trailer arm bushings
4mangoes
Rear suspension is making a nasty knock when going slow over a rough road .
Someone suggested replacing the trailing arm bushings. Where can i get those ? And how to replace them ?
Has thanked: 526 times
Been thanked: 269 times
WHO: Elephant Racing, 944Online, Tarrett, Paragon Products, Pelican Parts.....944Online has a lot of basic parts, Elephant Racing has several takes on level of parts, ...
HOW: There are you tube videos for bushing replacement, and Elephant Racing has instructions of various bushing replacements.
944m3
Has thanked: 25 times
Been thanked: 100 times
I would be surprised if that was the source of the knock.
I’d suggest to put the car up on stands and closely inspect everything. You can use a jack to “move” the suspension around. Could also be a bad exhaust hanger. I had a loose emergency brake cable mechanism (in the middle of the torsion bar carrier) that was loose. Would knock on bumps. I’ve also had a broken piece of honeycomb from the catalytic converter knocking around inside the exhaust. Finally, check the emergency brake pads and mechanism is secure in the drum. Yup I’ve had that come loose too.
If you feel it is the shoes inside the drum for the parking brake, they are held in place by springs. I had that issue as well.
The part number is 92835295702....here is a result from my google search and this particular one was from www.porscheatlantaperimeterparts.com
Parking Brake Shoe Hold Down Spring. Porsche 944. Genuine Porsche Part - 92835295702 (928-352-957-00, 928-352-957-01, 92835295700, 92835295701, ...
there are two per side...I ordered from Lindsey Racing as the piece price was $7 each but shipping was $20.
