Identifying a 968 Crankshaft
- Jotronic
- Has thanked: 58 times
- Been thanked: 32 times
How do you do this? I’m about to buy one but there are no part numbers on our cranks, just casting numbers. Is it something that can be identified from a photo? @Tom , do you know? I’m starting the parts accumulation phase for a 2.8 stroker and can’t afford to get this wrong.
- Has thanked: 943 times
- Been thanked: 4028 times
I have one of each out in the shop. I'll see if I can get you some tell-tale measurements.
Thinking about it, the 3 liter crank I have is probably an S2. Are you trying to distinguish between and S2 and a 968 crank, or just between a 2.5 and a 3.0 crank?
Got it. I think there is a weight difference between the two. @Thom posted about that in the past. He may be able to confirm.
- Thom
- The First Carpoke!
- Has thanked: 138 times
- Been thanked: 153 times
The 968 crank is slightly lighter than the S2's, like 25 kg instead of 27.5 kg. I would still not recommend dropping one on your foot.
I would not know about possible visual differences as I never really paid attention.
'90 944 turbo
