Question for those of you who have done their own oil change on a Boxster/Cayman GTS 4.0.
Most of the videos relate to the Flat 4. Many comments on the difficulty, especially with the PDK. I have seen a Jet Fuel Only oil change on a Cayman GTS 4.0 with PDK.
My questions for those with hands on experience.
Was there a headlight levelling arm needing to be disengaged for access to the filter? Hoping this is just a Flat 4 issue.
Did you use the Hazet 2169 tool or 2169-10? Appears that the only difference is depth? My guess is that the lower profile 2169-10 permits easier access given the limited space available.
Is the oil pan plastic, similar as the GT4?
Thanks in advance for your help.
Boxster GTS 4.0 Oil Change
- J-Dub
- Has thanked: 654 times
- Been thanked: 567 times
I did an oil change on mine back in October, so some of the details are fuzzy.
Yes plastic oil pan, just like the GT4. I did use a new plug and o-ring however the old one looked mint still. Next time i might only get a new o-ring.
I don't remember the level sensors getting in my way, I did have to remove them in the past when changing suspension components.
I used a universal three finger oil filter wrench. In the future I plan to try a 74 mm 14 flute wrench. They are available locally at the auto parts stores, Walmart etc however the Schwaben one seems like a good value. I would agree that the lower profile wrench looks easiest but you likely will be putting the wrench in place then the extension on to the wrench, not a lot of room to put the wrench up there with the extension attached.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
The headlight leveling arm needing to be disengaged only applies to the turbo-4 cars. On the 4-liter, the oil change is totally straightforward once you drop the undertray. I've done the job twice now, and will do it a third time at the end of the season. I used the Hazet 2169 Filter Wrench, ordered from Pelican Parts. Put a quart bag around the oil filter before you drop it to catch most of the spill. And yes, the oil pan is plastic - so the plastic drain plug simply twists into place. Don't overtighten it.
