Nuke fuel systems produces fulrails for 944
adonay
Has thanked: 2 times
Been thanked: 4 times
https://www.nukeperformance.com/produc ... fuel-rail#
Interesting to see that the 944 is stil getting more aftermarket parts
Nuke is known here in Skandinavia as the goto for fuel systems.
Zirconocene
Has thanked: 78 times
Been thanked: 48 times
Those are pretty pieces. It would be nice if they made some 16V parts, as well, which would carry over to the 928 S3 and S4.
Thanks for sharing.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
944m3
Has thanked: 20 times
Been thanked: 97 times
Very cool that we are still getting aftermarket parts.
But one thought, with a single bracket it will vibrate/shake like crazy, no? Or am I missing something.
mwc951
Has thanked: 12 times
Been thanked: 21 times
In the process of installing a Lindsey rail with Radium FPR & FPD and fuel lines.
Likes for the Nuke...injector retainer on the rail, AN thread on the inlet & outlet, Lindsey offers neither.
Dislikes for the Nuke...only 2 mounting points, early Lindsey rails had the same and caused problems, cosmetics are kinda funky.
I'd go with the Nuke, the 2 positives out weigh the negatives in my opinion.
JamesM
Been thanked: 11 times
Didn't the early Lindsey rails cause fires due to them only having two mounting points which is why they changed their design. This all could be hearsay, so I am curious if anyone else heard that.
mwc951
JamesM wrote: Thu May 09, 2024 6:36 am Didn't the early Lindsey rails cause fires due to them only having two mounting points which is why they changed their design. This all could be hearsay, so I am curious if anyone else heard that.
Yes, documented over on one of the other forums.
adonay
I had that old Lindsey rail i bought used from some lister . It seemed to fit the car and my simens injectors at the time. Felt solid on the car but did not use the rail as there was some leak or something from the marrel fuel dampener if i remember correctly.
Its a real shame if the 2 attachment design actually caused some real fires
