PSE Manual Control Switch Holder
Been thanked: 4025 times
Here are files to 3D-print a small switch holder for use with the soon-to-be posted Carpokes DIY PSE controller. This holder comes in two parts, which screw together. It is designed to work with a 3-way toggle switch from Adam Tech (Part No. SW-R2-2E-F-6-5) and similar switches from other manufacturers. Just about any plastic will do, but beware of PLA in a hot car. PETG or ABS are better choices. No support needed. Thin layers are best to form good threads (e.g. .2mm or less). The rocker switch snaps into place securely without tools or fasteners, and is recessed into the end of the holder to prevent unintentional changes to the switch position.
PSE Switch Holder Top.stl
PSE Switch Holder Bottom.stl
