My 2013 base Boxster has 36K and has been serviced by a Porsche dealer. It runs perfectly with zero issues, except, I got a light "Fault Engine Control Possible to drive on". Fluids are good and I run Exxon 93 gas almost exclusively. No mods to the engine.
Any ideas? I'm 3 hours from the nearest Porsche dealer so it would be great if I can avoid the trip.
Thanks.
Engine fault light
- P_Coastal
- Has thanked: 1047 times
- Been thanked: 618 times
You need a scan to see what faults have been logged. Any decent shop can do that to give you more information to determine whether a dealer trip is warranted. Good Luck !fasteddie9 wrote: Mon Mar 25, 2024 10:34 am My 2013 base Boxster has 36K and has been serviced by a Porsche dealer. It runs perfectly with zero issues, except, I got a light "Fault Engine Control Possible to drive on". Fluids are good and I run Exxon 93 gas almost exclusively. No mods to the engine.
Thanks.
- Has thanked: 941 times
- Been thanked: 4026 times
Check to make sure your gas cap is clicked shut. Ask me how I know. If it wasn't clicked, it can take a day or two of driving for the warning to go away. Otherwise, you can get an OBDII port reader for peanuts these days (like under $10 on amazon!), and reader will give you the fault code so you know what the issue is. Or, as P_Coastal says, just about any auto shop can scan for the codes and tell you what triggered the warning. Fingers crossed it's something cheap and easy.
fasteddie9
- Has thanked: 2 times
Thanks for the info. I'll check the gas cap and also get a shop to scan the OBD. I hate to sound dumb, but, being old school, I didn't know if this required an OBD scanner specific to Porsche. Again, thanks.
fasteddie9
Looking for suggestions on a particular OBD scanner to consider. Again, this is new to me and I have no clue on comparing units. I should have had a scanner some time ago but I'm about to be educated.
fasteddie9
My buddy has a small, basic reader. He says its a "small evap leak" code. Check gas cap and hoses, but ok to drive. I haven't had the car on a lift to see the engine yet. Is it hard to access?
