I got my Blackstone report yesterday and iron was 16, up from a consistent 4-7 on previous reports. The universal average number is 9ppm. Same oil and change intervals, and no hard driving. I'm pretty sure this is not a terrible number, but I do wonder why it is up.
So my question is: Which components on the 3.6 would possible generate iron? I suppose camshafts and the crank, but beyond that I don't know. I believe this engine came with the "Lokasil" coated pistons...does Lokasil contain any iron???
Any input, much appreciated! Or, do you think this is just a big nothing-burger? At what ppm should a guy be concerned about higher than normal numbers?
Thanks a lot! -Tom
Iron is up slightly...
- aboyandhisdog
- Has thanked: 136 times
- Been thanked: 57 times
- 911-Purist
- Has thanked: 39 times
- Been thanked: 43 times
And that is a question I have often asked myself.aboyandhisdog wrote: Sat Mar 23, 2024 10:37 amAt what ppm should a guy be concerned about higher than normal numbers?
I have never done an oil analysis in almost 50 years of vehicle ownership...cars or motorcycles. And some of them have had high mileages.
For the fun of it, I'd love to send an oil sample from a drain to two different oil analysis outfits and see if I get the same numbers. Having been in the calibration business (electrical), I like to question the numbers I get. If I get a cal certificate without any traceability to NIST or what have you, it is meaningless.
Alex
I agree with you on sending in oil for an analysis. I prefer to have some insight on what's happening inside the engine. I'm not one to look away in blissful unawareness.....but that's just me. Different strokes for different folks.
The idea of sending off two oil samples is intriguing. Never done two. If you want a second opinion, look for your local Caterpillar Heavy Equipment dealer. They usually have an oil analysis lab on premises. I get mine done locally and I believe it's around $18 if I recall. As a point of reference for you, the last oil sample I sent out for my engine came back with an iron reading of 4 on an engine with 36K miles. If that goes up substantially over two or three samplings, I'd probably start to investigate. Like I said, that's just me.
As usual, there's the usual caveat here. All of this is all just my opinion and I could be wrong and YMMV.
JC 96 TT
JC 96 TT
- aboyandhisdog
If my memory serves, the Wix and Balckstone labs use the same testing equipment and methodology so the results are "apples to apples". Speed Diagnostics uses a different method of testing and the results will not be on the same playing field as the others. In fact, Speed Diag. tells you up front to stick with your lab of choice and do not switch labs if you want to have results you can compare over time.
I do 100% agree with you...better to learn the trends in an engine than to be ignorant of what might be going on in the engine. My iron #'s may be nothing, but at least now I know to keep an eye on them at every oil change.
cavediver32043
- Has thanked: 14 times
- Been thanked: 10 times
Just a note; you have a Lokasil block vs Lokasil coated pistons. I am an advocate of pulling UOA samples.
- 911-Purist
No matter what method or system you use, when you have 9 ppm of a material in your oil, you should see that in any report from any company.aboyandhisdog wrote: Fri Mar 29, 2024 5:01 pm If my memory serves, the Wix and Balckstone labs use the same testing equipment and methodology so the results are "apples to apples". Speed Diagnostics uses a different method of testing and the results will not be on the same playing field as the others. In fact, Speed Diag. tells you up front to stick with your lab of choice and do not switch labs if you want to have results you can compare over time.
If SpeedDiagnostix tells you not to switch labs, that is pure BS and provides you with a relative number to the last test done with them, but it may not be accurate. Any lab that takes any type of measurement has to be traceable to a standards lab or what they are providing is garbage.
Also, 9 ppm of iron means nothing. What does it mean in real world wear on an engine if you take an oil sample once a year over a ten-year cycle.
Isn't it wonderful to capitalize on "fear". Look at any oil thread.
Alex
Tom,
I feel a bit sorry that you didn't receive any useful replies to your actual question.
With that in mind, did Blackstone comment on the change in iron level in your latest sample? I have used Blackstone for my 997.1 911 and my E60 M5, both fantastic cars with known engine reliability issues, and Blackstone has consistently commented on any changes, or lack thereof, in the oil analysis results. Your iron level change seems notable so, if Blackstone didn't mention it, my first step would be to ask them directly for their assessment of the change.
Good luck, hope this helps,
Grant
Grant
- aboyandhisdog
Thanks, Grant. Yea, I was hoping somebody would know the source of iron in this engine in particular. I'll try to post the Blackstone report here but not sure if it will post or not. Anyway, they did mention the valve train and the cylinders, but I don't think this engine has iron cylinders. I'm wondering if their comments were to just engines in general and not Porsche 3.6 specific. I'm sure I could research this elsewhere, but mark that down to me just being lazy! Appreciate your input!
file:///Users/tomfitch/Downloads/S034880.pdf
- Has thanked: 4604 times
- Been thanked: 2498 times
Hey Tom,aboyandhisdog wrote: Sat Mar 30, 2024 4:11 pm Thanks, Grant. Yea, I was hoping somebody would know the source of iron in this engine in particular. I'll try to post the Blackstone report here but not sure if it will post or not. Anyway, they did mention the valve train and the cylinders, but I don't think this engine has iron cylinders. I'm wondering if their comments were to just engines in general and not Porsche 3.6 specific. I'm sure I could research this elsewhere, but mark that down to me just being lazy! Appreciate your input!
You can post PDFs directly on Carpokes. Just use the regular Attachments tab > Add Files and navigate to the PDF on your PC that you wish to share, the same as you would do for photos. It will post as a file, similar to what you did above but will be an actual link that will open in whatever PDF reader the person who clicks it has on their PC or device. It'll look and behave like the weekly Autoweek race schedules from the web that I "print to PDF" and save via my PC's printer menu, like this:
The Blackstone report is probably too large for a decent screenshot but if it happens to be a single page, a screenshot might also be a possible work-around as an image post. It's what I use when necessary. Like this partial page from the GT4's Racing on the Circuit manual:
