Has anyone attempted to create a 3D printed rear main seal installation tool?
ALEXtheGREAT
Just thought of this the other day and figured it maybe a handy tool to have. I borrowed an SST tool from my workplace that got the seal started but the inner diameter wouldn't clear the end of the crankshaft like a proper rear main seal SST for our engines would.
Has anyone attempted to create an 3D such a tool for our rear main seals?
Has thanked: 594 times
Been thanked: 668 times
Paging @Tom the Magic Man
Has thanked: 951 times
Been thanked: 4078 times
That's a good idea! I have not seen a model for it, but I do have the factory tool (after a DIY PVC tool resulted in a leak), so could work off that to model one. I'll put it on the list, but it will be a while I'm sure -- so maybe not a solution to your immediate issue. :(
ALEXtheGREAT
Tom wrote: Thu Jun 29, 2023 4:16 pm That's a good idea! I have not seen a model for it, but I do have the factory tool (after a DIY PVC tool resulted in a leak), so could work off that to model one. I'll put it on the list, but it will be a while I'm sure -- so maybe not a solution to your immediate issue. :(
No worries! Reason I brought it up was because I'm pretty sure my rear main seal is leaking due to improper installation. I must've either not driven it in all the way (according to the FSM the seal actually bottoms out against a stop, which I'm not used too) or maybe damaged it with my Toyota SST lol.
Zirconocene
Has thanked: 78 times
Been thanked: 51 times
I believe that there is one designed by someone over on RL. Let me see if I can find you the link to Thingiverse (?); the design file was made publicly accessible.
ETA: Here you go - https://www.printables.com/model/205318 ... ation-tool
ETA2: Jinx!
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
ALEXtheGREAT
Zirconocene wrote: Fri Jun 30, 2023 11:34 am I believe that there is one designed by someone over on RL. Let me see if I can find you the link to Thingiverse (?); the design file was made publicly accessible.
ETA2: Jinx!
Oh wow great find! I'll definitely look into this! Thanks!
Let us know how it goes. .STL's can be hit or miss, so if this one has any issues, I'm still happy to make one here. :)
Latitude48
Has thanked: 107 times
Been thanked: 115 times
I have a printed one I got from RL. Not sure I'll ever use it. I can post a few pictures if anyone wants to see how it works.
Tom Pultz
ALEXtheGREAT
Tom wrote: Fri Jun 30, 2023 11:42 am Let us know how it goes. .STL's can be hit or miss, so if this one has any issues, I'm still happy to make one here. :)
Will do! I read the one and only comment on the website for that .STL and the user said he had some difficulty with his first printed tool. Seems like this particular tool maybe a bit hit or miss. There's no substitute for the official tried and true Porsche tool. Not really wanting to drop 200-300$ on the Porsche tool either lol.
