After finishing clutch install and completing reassembly, I am experiencing intermittent stalling/hesitation on acceleration.
Wondering if I might have switched the vacuum hoses on the wastegate (Lindsey dual port). Would this have any effect?
Have switched hoses and and garage start sounds better. Have not had back out on street under load. Will recheck grounds as well. Seems like a vacuum issue.
Wastegate help please
- Been thanked: 4025 times
Sorry I missed this till now. Stumbling on heavy throttle, but driving fine otherwise, is often the first sign of a weak ignition. Spark plug wires are an often-overlooked culprit if yours are old, along with good cap, rotor and plugs (gapped to spec or less). The speed and ref sensor gap is not a likely cause of stumbling/hesitation under boost. Their signals only get stronger with RPMs, and generally they either work or don't work.
Worth re-checking all your couplers too if you have reason to think it's a boost leak. Do you have a wideband?
What happens to the AFR when it starts to sputter? Do you see it going lean or rich before it starts acting up?
Depends on if you are in vacuum or boost. If it goes lean while boosting, that can cause knock/pinging and compromise the head gasket. If it runs lean under vacuum, and then rich on boost, that's more likely a vacuum/boost leak. Maybe take a video of it hesitating/sputtering so we can get a better idea what you are dealing with.
How old are you plugs, wires, cap and rotor?
Solution (fingers crossed). Corrected the gap on the reference sensor and problem has resolved. Now runs normally without faltering. Boosts correctly. I have read on multiple sites that reference sensor is only operable on startup. My experience would indicate otherwise. Thanks for all the suggestions.
