I'm looking at using some 996 brakes on my other car, and I have a few questions if anyone can answer.
-All 996 brakes are radial mounted, do they all use the same bolt spacing for that? I heard the only difference is a spacer to push the caliper out farther for the Turbo and GT3?
-986S, 996 C2 & C4 share one brake setup, the 996 C4S and Turbo share another, and the 996 GT3 and GT2 share one (plus having the PCCM rotor and pad setup)
-Does the offset of the rotor change at all?
-Does the wheel clearance get worse with the two bigger brake setups?
Question about 996 Brakes
Update to my own post:
986S and base 996 (C2 and C4) use one caliper type, and they have a separate bolt pattern than the C4S/Turbo calipers. GT3 calipers exchange with C4S/Turbo type, but require being spaced way out.
Base 996 calipers can be uprated to 350mm rotors too using spacers on the caliper.
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
IG: @stitch2k1
