Sunroof operation
Don_Cote
Has thanked: 15 times
Hello,
I am trying to trouble shoot my non functioning sunroof on my 1986 turbo. I found one bad relay by the motor that controls the direction, 431 951 253D. When I press the switch the other relay clicks but nothing else happens. I removed the motor and connected it to a 12V source and the motor turns but it pulses, is this normal ? I also checked the fuse in the main fuse block under the hood and it is good. Is there possibly another fuse somewhere else or another relay ?
Don
Dave W.
Has thanked: 4 times
Been thanked: 22 times
There are two limit switches in the motor/cable assembly that can be out of adjustment or stop working. Clarks-Garage has a few good pages for troubleshooting the sunroof.
See
http://www.clarks-garage.com/shop-manual/body-03.htm
http://clarks-garage.com/shop-manual/re ... index4.htm
Don_Cote
Thanks Dave I’ll have a look at it.
usury
Has thanked: 100 times
Been thanked: 93 times
This YouTube video may also be helpful
and Wrench Warrior
Seattle, Washington, USA
Darwin
Has thanked: 116 times
Been thanked: 74 times
usury wrote: Sat Oct 22, 2022 6:27 pm
IDK when they made the change, but at least some 86 Turbos have the early style sunroof mechanism. Porsche made a retrofit kit, but the last one was purchased about a year ago.
2012 VW Tiguan - Kinda stock
crackership
Has thanked: 38 times
Been thanked: 9 times
Darwin wrote: Mon Nov 21, 2022 3:17 pm
How can you tell if you have an early or late sunroof mechanism? Inquiring owners of 86 Turbos wanna know :)
-Dave
Build Thread (Now on Carpokes!)
JerVegas
Has thanked: 16 times
crackership wrote: Wed Nov 23, 2022 4:06 pm
+1
Jer
Darwin
Early:
Late:
