Alternate Alternator Options/Sources
cda951
Has thanked: 138 times
Been thanked: 81 times
Darwin wrote: Fri Feb 28, 2025 3:15 am Just found out that my single wire alternator was the source of a significant battery drain. Self exciting single wire alternators are known for this, I guess...I recently swapped back to an OEM unit and my problem completely disappeared. Just for info, in case anyone else is looking at going to a single wire alternator.
Yeah, single-wire alternators are for tractors, they at some point crossed into the aftermarket as an "upgrade" with idiot-proof wiring, which is great for a very simple '32 Ford hot rod, not as great for a car with modern engine management, high-wattage headlights, stereo, etc.
Good info here:
http://www.madelectrical.com/electrical ... wire.shtml
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
#51
Darwin
Has thanked: 116 times
Been thanked: 74 times
cda951 wrote: Fri Mar 07, 2025 9:38 pm
Good info here:
If only I knew this before I went through all the trougle of converting! Now I have a nice paperweight for an alternator with no real way of unloading it!
2012 VW Tiguan - Kinda stock
#52
Darwin
dme wrote: Fri Mar 07, 2025 3:32 pm
When my Nissan alternator failed it would drain the battery while sitting overnight. I have a lifetime warranty on my Autozone Nissan/Mercury alternator so the failure didn't cost me anything but time for R&R.
This has me curious if I have a failure or not, but my alternator has less than 2k miles on it and I bought it probably 8 years ago from autozone in UT (now I live in CA) I swapped back to stock and my voltage is fine and my problem is gone. Hopefuly someone can learn from all of this!
#53
chrischrischris
Has thanked: 7 times
Been thanked: 36 times
I didn't know that any 944 had a "check engine" light.
#54
SirLapsalot
Been thanked: 19 times
chrischrischris wrote: Wed Apr 09, 2025 11:58 am I didn't know that any 944 had a "check engine" light.
Not sure what model years it was first introduced with, but the dash cluster I installed in my car and is shown in the picture earlier was from an 87 parts car I had. The original dash in my 86 did not have the check engine light IIRC.
#55
stitch2k1
Been thanked: 30 times
So what's the good source for an alternator? Straight from Nissan? Plus where to buy a 6 rib pulley for it?
Did that new bracket get made?
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
#56
fasterfaster
Has thanked: 165 times
Been thanked: 24 times
edit: NM, decided to keep my Nissan alternator for a later install.
Marc
88.5 951 M030 Red on Black
#57
rheidtman
Has thanked: 33 times
Been thanked: 11 times
For those looking to retain the OE Bosch 90A/115A alternators, I now have all the parts and cores to start rebuilding.
Yet another on the endless list of parts I rebuild... Drop me a note if interested.
Rick
Oak Creek, WI
1989 951
1989 928
2015 Panamera Turbo S
#58
stitch2k1
rheidtman wrote: Sat Jan 24, 2026 8:54 am For those looking to retain the OE Bosch 90A/115A alternators, I now have all the parts and cores to start rebuilding.
Rick
Oak Creek, WI
What's your price on rebuilds? My car needs the smaller alternator, but I've got plenty of cars that just need a regular one.
IG: @stitch2k1
#59
rheidtman
My rate for a 90 or 115A OE Bosch alternator is $375, plus a core charge of $300. My preference is surely to receive the original alternator back to allow continued rebuilding....
Sadly, yes, these alternators are now getting crazy expensive. A quick review of Pelican shows a rebuilt unit is now over $1300 with a hefty core charge... 944 Online has been out of stock for months...
https://www.pelicanparts.com/More_Info/ ... DID=282971
1989 951
1989 928
#60
